3G and DSL on 881G
Latchum Naidu
Hi All,
We have both DSL and 3G connection to the 881G and both are up and running.
There is a NAT for easy vpn device (10.10.10.2) on this router and currently pointing to DSL interface IP (206.206.206.9)
********ip nat inside source static 10.10.10.2 206.206.206.9 extendable*********
My current requirement is that NAT for easy vpn device should work on 3G if DSL link down.
So how we can achive the NAT redundancy....Can someone help me on this...
Even when i removed the above NAT and pointing to Cellular0, I am not seeing any translations.
Thanks in advance.
Naidu.
sean_evershed
Level 7
Level 7
Ha...I was seeing the same doc
But I found no translations on the Cellular interface.
Hi All,
Now the problem has resolved by configuring the two default routes with one high AD and also dual NAT...
Thanks for all....
Naidu.
islamamir
Hi Latchum Naidu
Can you please share your configuration? i have a similar task to configure failover between ADSL and LTE 4G on Cisco 881 Router.
