05-08-2012 01:02 AM - edited 03-04-2019 04:17 PM
Dear All,
This is with reference to 3G as backup link over MPLS network,we have to configure the 3G as back up for the MPLS leased line.So we have already configured the necessary configurations in router and configuration form ISP side also is done.This secondary link is became up once the primary is down. But it is not connecting to our MPLS-VPN network and it is connecting to internet. The negotiated IP have to assign as a private for the cellular interface but it is assigned as a public ip address.We have attached the output cellular interface configuration of "" and "sh cellular ".
Please help us to resolve the issue.
interface Cellular0/3/0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 10
dialer string gsm
dialer-group 1
async mode interactive
ppp chap hostname (username)
ppp chap password 0 (Password)
interface Dialer0
encapsulation ppp
dialer pool 1
dialer string gsm
dialer-group 1
ip forward-protocol nd
i
ip route 0.0.0.0 0.0.0.0 172.19.98.26
ip route 0.0.0.0 0.0.0.0 Cellular0/3/0 200
ip route 10.0.0.0 255.0.0.0 172.19.98.26
Router#sh cellular 0/3/0 all
Hardware Information
Modem Firmware Version = K1_0_2_18AP C:/WS/F
Modem Firmware built = 12/29/08
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 404663200059012
International Mobile Equipment Identity (IMEI) = 011955000045676
Factory Serial Number (FSN) = D66089014071021
Modem Status = Online
Current Modem Temperature = 38 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = bsnlvpn(APN name)
Authentication = CHAP
Username: (username).in, Password: (password)
Profile 2 = INACTIVE
PDP Type = IPv4
* - Default profile
Gopal
05-08-2012 02:20 AM
If I understand correctly, your issue is that the cellular interface got a public IP address, instead of the private one?
When you configure 'ip address negotiated', the interface will accept the IP address sent by the ISP.
If you want to use the cellular interface as secondary link, you will have to agree with your ISP on the private IP address to assign. The ISP will also have to associate the IP with your MPLS network.
In alternative, you can create a tunnel over the cellular interface (with the public IP) where you can assign the private address.
Marco
05-08-2012 02:42 AM
Thanks for your update.!
Is there any configuration changes required on router side for 3G back up? .
What are the configuration changes required for tunnel over the cellular interface (with the public IP).
Gopal
05-09-2012 02:07 AM
Gopal, I think you need to discuss this with your ISP.
What you are trying to do can be done, but it requires specific configuration on ISP side.
Scenario 1: The ISP will assign you a private address that you previously agreed on.
In this case, no configuration changes are needed on your router.
Scenario 2: The IP will not be automatically assigned.
You will have to configure manually the IP under the dialer/cellular interface.
Scenario 3: A public IP will be assigned by the ISP. You want to build a tunnel to a remote router.
On your router, you will have to define a tunnel that use the public IP of the cellular interface, and a public IP of your remote router.
The tunnel can be GRE or VPN, depending on your needs.
Note: in your config, you are using both cellular and dialer interface.
Usually this is not needed, the whole configuration can be done on the cellular interface itself.
However, you can use the dialer interface, but it's not a good practice to add commands in both interfaces, e.g. 'ip address negotiated'
