3G interface Configuration
goutam_04
I have configured 3g interface on my router, the link is up and running but the link is goes down/idle when nobody is using the link.  Its works like dial on demand.
I want to make this interface all the time up.  Is there any command line to make this interface always up and connected.
davy.timmermans
Level 4
Level 4
Can you try to add the command under interface configuration cellularx/x/x:
dialer persistent
Best regards
Thanks...
I will check...
