4 group in the same LAN each group go out through specific ip address
akhnoukhca
Hi All,
I have 5 public ip address from the ISP come to 4 port D-link router and the isp does not allow any one to go through this router.
we have 3 groups in the LAN let's say 1- phones 2- AP 3- PC all should hae same Lan ip range of course DHCP not static
my question is how we make each group go outside to the internet through specific one of the public ips we have ?
and which equipment we need if we need just L3 switch or we need router and switch  ?
thanks Guys,
Hello
Suggest you separate your 3 vlans internally ( phone/aps-pcs) then perform NAT on these internal subnets  against your public addresssing supplied by your isp.
lasty create dhcp pools for all 3 internal subnets for your clients.
You can do this all on the router is you wish, with a switch attached to its interface for access assigment.
Basic Example:
ISP supplied addressing = 10.1.12.0/29 ( mask 255.255.255.248)
router facing ISP
ip dhcp pool vl10
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.254
   domain-name test.com
   dns-server 100.100.100.1
   lease 0 8
ip dhcp excluded-address 10.10.10.254
ip dhcp pool vl20
   network 20.20.20.0 255.255.255.0
   default-router 20.20.20.254
   lease 0 8
ip dhcp excluded-address 20.20.20.254
ip dhcp pool vl30
   network 30.30.30.0 255.255.255.0
   default-router 30.30.30.254
   lease 0 8
ip dhcp excluded-address 30.30.30.254
ip nat pool vl10 10.1.12.4 10.1.12.4 prefix-length 29
ip nat pool vl20 10.1.12.5 10.1.12.5 prefix-length 29
ip nat pool vl30 10.1.12.6 10.1.12.6 prefix-length 29
ip nat inside source list 10 pool vl10 overload
ip nat inside source list 20 pool vl20 overload
ip nat inside source list 30 pool vl30 overload
access-list 10 permit 10.10.10.0 0.0.0.255
access-list 20 permit 20.20.20.0 0.0.0.255
access-list 30 permit 30.30.30.0 0.0.0.255
interface FastEthernet0/0
description WAN LINK
 ip address 10.1.12.1 255.255.255.248
 ip nat outside
interface FastEthernet0/1
description LAN LINK to Switch
interface FastEthernet0/1.10
description Phone Vlan
 encapsulation dot1Q 10
 ip address 10.10.10.254 255.255.255.0
 ip nat inside
interface FastEthernet0/1.20
description AP Vlan
 encapsulation dot1Q 20
 ip address 20.20.20.254 255.255.255.0
 ip nat inside
interface FastEthernet0/1.30
description PC Vlan
 encapsulation dot1Q 30
 ip address 30.30.30.254 255.255.255.0
 ip nat inside
ip route 0.0.0.0 0.0.0.0 10.1.12.2 name Next-hop-to-isp
Switch
int x/x
description Uplink to router
switchpor trunk enacp dot1q
switchport mode trunk
int fa0/1
description Phone access port
switchport host
switchport access vlan 10
int fa0/2
description AP access port
switchport host
switchport access vlan 20
int fa0/3
description PC access port
switchport host
switchport access vlan 30
res
Paul
Kind Regards
Paul
