4 port clear channel HWIC T1 Cards
marcuslove
Group:
Does the clock source have to be the same at both ends or does one need to be internal and the other set to line?
THANKS
vmiller
Level 7
Level 7
If you are a using TELCO provided circuit, set both ends to line.
If you building your own (no carrier services at all) then try the one internal and one line.
