4 router on a packet tracer configure correct
iDAMedic
Can you help me correct the topology, consider the address 150.67.0.0
Applying the RIP protocol in all routers so that there is connectivity throughout the network.
I share the example .pkt I have everything created but I am not sure that I send the messages.
They can help to review the file.
2 Accepted Solutions
Deepak Kumar
Here is your working lab.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Exactly. Announce all networks/interfaces on each router in RIP, in order to have full connectivity throughout the network...
6 Replies 6
Deepak Kumar
There is two issue:
Your subnet /20 is overlapping with each other subnet and RIP is not configured properly. I will share working PT soon
Deepak Kumar
Deepak Kumar,
Deepak Kumar
Deepak Kumar
Deepak Kumar,
I really appreciate you. I'm going to review it right now
Thank you.
I think you forgot to announce network 150.67.0.0 in RIP on the rightmost router...other than that, it is working. Since I was working on the lab as well, either way, here is my version, with verified end to end connectivity from and to all PCs...
Thank, RIP protocol on all routers so that there is connectivity throughout the network?
