4321 Boost License Help
StevenH01
Hello all,
  I've been given a couple of Boost licenses to load and it's in another state. I was told that the previous integrator tried and the licenses were invalid. I'm a bit skeptical on what SN they were assigned to. I'm waiting on the chassis numbers from the original integrator, but from I've read the Chassis SN is supposed to be in the beginning of the License. Both licenses I was given starts with "FLM". One starts with "FLM2306050P_" I believe the first three letters are supposed to be the origin country. I can't find FLM anywhere. I did find FLM when I punched in "sh ver" and the processor ID starts with FLM. Any help would be great.
Thanks!
pieterh
try "show udi" to retriever both product-ID and SN
check if this SN is part of your license-ID
NB! I think license itself is called FL-4320-BOOST-K9
Did the trick, SN matches up. thank you!
