ASAv Act/Pass HA HyperV Propergating ARP
Mux
G'day
I have an environment with two HyperV (HPX) servers in the same domain.
HPX01 has AD01
HPX02 has AD02
both residing in the same VLAN, independently connected via LACP to a 3850 (16.12), which is running OSPF.
We have built a proof of concept(POC) with an ASAv installed on each HPX as a virtual appliance... However, since this initial POC, we can't get the two ASA's to pass ARP / IP's that are specific to the other HPX - e.g. HPX-AD01 can't ping or connect to HPX-AD02 specific IP - 10.10.10.20/24 can't ping 10.10.10.22 /24 - They are in the network, residing on different HXP.
We have now have to install ASAv on both HPX, and need to iron out this config.
  1. ASA's running in Active / Passive mode and they are syncing configs.
  2. I can see OSPF routes updating between the Switch and ASA's
  3. HPX-ASA01 can ping local servers in LAN 30 (VLAN300), but can't ping any on HPX-ASA02
  4. HPX-ASA02 can ping local servers in LAN 30 (VLAN300), but can't ping any on HPX-ASA01
  5. Since installing the ASAv(s) now the HyperV Servers can't connect (so it's not just icmp) HyperV manager or sync
  6. sh arp on HPX-ASA02, only sh's arps for HPX-ASA01.
Thoughts? Suggested troubleshooting?
Cheers,
Mux
Jon Marshall
The virtual switch you created was an external switch ?
Is vlan 300 the inside interface of the ASAs ?
Are you allowing vlan 300 on the team that connects each hypervisor to the 3850 switch ?
Are you using the management vlan for the hypervisors for the ASAs as well ie. are the outside interfaces of the ASAs in the management vlan ?
Also just to clarify these are two separate hyper-v servers ie. you are not running them in a cluster are you ?
If you could explain the topology in a bit more detail ie.  vlans/IP subnets in use etc. that might help.
Jon
