4321 IOS-XE upgrade
Hi all,
tried upgrading IOS-XE on Cisco 4321 ISR but it didn't work.
In other words, copied the bin file to flash, modified bootvar, saved it, verified it got saved and rebooted the ISR.
It booted with the old image.
What do you recommend?
johnlloyd_13
Level 9
Level 9
hi,
did you change to boot variable?
no boot system bootflash:<OLD IOS>.bin
boot system bootflash:<NEW IOS>.bin
see helpful link:
http://wannabelab.blogspot.com/2017/02/cisco-4331-router-ios-and-license.html
johnlloyd_13
Level 9
Level 9
hi,
see helpful link:
Thanks, it worked.
wrong was:
boot system flash:<NEW IOS>.bin
CORRECT:
dkikko2
Ran into a similar problem with an ISR 4321 router that took a few steps to correct the upgrade firmware issues:
Upgrade isr4300-universalk9.03.15.00.S.155-2.S-std.SPA.bin to isr4300 universalk9.16.06.09.SPA.bin
Located isr4300-universalk9.16.06.09.SPA.bin
Image size 789165506 inode num 14, bks cnt 192668 blk size 8*512
Boot image size = 789165506 (0x2f09b5c2) bytes
Package header rev 3 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
               calculated 4772c8cd:503f7b78:aa516c67:87eca434:d95dc400
               expected   4772c8cd:503f7b78:aa516c67:87eca434:d95dc400
Signature verification failed for key# 2
Signature verification failed for key# 3
Failed to validate digital signature
RSA Signed REVOCATION Image Signature Verification Failed.
Package Load Test Latency : 12415 msec
Unsigned package found,  aborting ...
boot: error executing "boot bootflash:isr4300-universalk9.16.06.09.SPA.bin"
autoboot: boot failed, restarting...
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S3, RELEASE SOFTWARE
Copyright (c) 1994-2014  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Cisco ISR4321/K9 platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
File size is 0x1bc32520
Located isr4300-universalk9.03.15.00.S.155-2.S-std.SPA.bin
Image size 465773856 inode num 12, bks cnt 113715 blk size 8*512
Router#show platform
Chassis type: ISR4321/K9
Slot      Type                State                 Insert time (ago)
0         ISR4321/K9          ok                    00:01:53
 0/0      ISR4321-2x1GE       ok                    00:00:47
R0        ISR4321/K9          ok, active            00:01:53      (R0 is letter R and number 0)
F0        ISR4321/K9          ok, active            00:01:53
P0        Unknown             ps, fail              never
P2        ACS-4320-FANASSY    ok                    00:01:36
Slot      CPLD Version        Firmware Version
*************************************************************(need to upgrade rom-monitor to install IOS above 16)***************
0         17100927            15.4(3r)S3
R0        17100927            15.4(3r)S3
F0        17100927            15.4(3r)S3
********************************Tried upgrading the hw-programmables versions didn't help)**************************************
Router#show hw-programmable R0 all
Hw-programmable versions
Slot              CPLD version              FPGA version
R0                17100927                  N/A
F0                17100927                  N/A
0                 17100927                  N/A
Router#dir
Directory of bootflash:
   14  -rw-        789165506  Jun 28 2022 18:49:34 +00:00  isr4300-universalk9.17.06.03a.SPA.bin
   15  -rw-         16057308  Jun 29 2022 14:51:50 +00:00  isr4300-hw-programmables.16.07.02-ext_v2.07.SPA.pkg
Router#show rom-monitor R0  (Remember R0 {R zero})
0         ISR4321/K9          ok                    00:11:46
 0/0      ISR4321-2x1GE       ok                    00:10:40
R0        ISR4321/K9          ok, active            00:11:46
F0        ISR4321/K9          ok, active            00:11:46
P2        ACS-4320-FANASSY    ok                    00:11:28
******************THIS WILL FIX THE IMAGE UPGRADES FROM BEING REJECTED:*********************************
*****Download from Cisco.com and upload to the router flash: isr4200_4300_rommon_1612_2r_SPA.pkg*******************
*****************You can copy from a supported external flash drive so tftp isn't necessary:*************************
Router#copy usb0:isr4200_4300_rommon_1612_2r_SPA.pkg bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg
***************************use the upgrade command and don't forget to add the word (all) after .pkg*****************************
Router#upgrade rom-monitor filename bootflash:isr4200_4300_rommon_612_2r_SPA.pkg all
Chassis model ISR4321/K9 has a single rom-monitor.
Upgrade rom-monitor
Target copying rom-monitor image file
selected : 0
Booted : 0
Reset Reason: 0
Info: Upgrading only BIOS from the rommon package
4259840+0 records in
4259840+0 records out
262144+0 records in
262144+0 records out
655360+0 records in
655360+0 records out
File  is a FIPS ROMMON image
FIPS-140-3 Load Test on  has PASSED.
Authenticity of the image has been verified.
Switching to ROM 1
8192+0 records in
8192+0 records out
Upgrade image MD5 signature is 871f9d7df678f0c4ea92b7c9c4dfa88c
4194304+0 records in
4194304+0 records out
262144+0 records in
Upgrade image MD5 signature verification is 871f9d7df678f0c4ea92b7c9c4dfa88c
Switching back to ROM 0
ROMMON upgrade complete.
To make the new ROMMON permanent, you must restart the RP.
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019  by cisco Systems, Inc.
Current image running: *Upgrade in progress* Boot ROM1
Last reset cause: BootRomUpgrade
**********Reload the router to finalize the ROM upgrade, the new image will load System image file is "bootflash:isr4300 universalk9.16.06.09.SPA.bin"******************************************************************************************************
Package header rev 1 structure detected
IsoSize = 553878818
Calculating SHA-1 hash...Validate package: SHA-1 hash:
               calculated 95606043:88CA98F9:31FFAA78:F38297E0:54399D4D
               expected   95606043:88CA98F9:31FFAA78:F38297E0:54399D4D
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Router#show version
Cisco IOS XE Software, Version 16.06.09
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.9, RELEASE SOFTWARE (fc3)
