4331 NIM-2GE-CU-SFP GE-LH-SMD --> Controller speed question
matthewlacomb
I have 2 sites that are connected via a dark fiber (1gbps).  Having an issue to where pushing more than 100meg over the circuit shows tail drops on one side; we found the following while doing a show int gi0/1/0 controller:
interface GE0, iid 1, port_id 16, admin up(config up), link up
media type auto, current media SFP, failover false, duplex full(config full), autoneg, speed 1G (config 100M)
Long story short, why is the (config 100M) there?
interface GigabitEthernet0/1/0
description Point to Point
ip address x.x.x.x 255.255.255.252
load-interval 30
negotiation auto
service-policy input YYY
end
balaji.bandi
you may have dark fiber - but what is the bandwidth you have ordered from the provider?
Another one is Line speed in bits per second - to make more clarify are you sending 100megabits or bytes?
when you sending 100M - can you post show interface Ge0/1/0 human
Try
no negotiation auto
BB
Leo Laohoo
Please post the complete output to the following command:
sh interface Ge0/1/0 control
#sho int gi0/1/0 cont
GigabitEthernet0/1/0 is up, line protocol is up
Hardware is NIM-2GE-CU-SFP, address is 00bf.7729.d888 (bia 00bf.7729.d888)
Description: PTP
Internet address is 10.255.255.113/30
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Full Duplex, 1000Mbps, media type is LX
output flow-control is on, input flow-control is on
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 23:51:55
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 37
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
30 second input rate 784000 bits/sec, 303 packets/sec
30 second output rate 1194000 bits/sec, 333 packets/sec
10037666 packets input, 3322778761 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 1731 multicast, 0 pause input
12369239 packets output, 7477264308 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
flow control tx config: enabled
PHY status: enabled/enabled
MAC : bf7729d888
flow control (config/state): Pause/Pause, threshold on/off/max: 512/3072/3328
counter in queue: 28(left-over=14/3/11), threshold: 3072
RED alert number: 0, red alert not active
pause state: XON, Pause Enable Number: 0
MAC filter enabled
inq in-LP: packet 503616966, bytes 136899092271 drop 0, error 0
red alert watermark 6656, BPID internal count 28
Errors:
partial: 0, jabber: 0, overrun: 0, oversize: 0, alignment: 0,
fragment: 0, gmx_fcs: 0, undersize: 0, extend/terminated: 0, length: 0,
gmx_rx: 0, skip: 0, nibble: 0, pip_fcs: 0, pip_skip: 0,
pip_l2_mal_hdr: 0, puny: 0, unknown: 0,
outq LP traffic: packets 1160396890, bytes 1308006044210, drops 0, error 0
packets/bytes in queue 0/0, max backup 0, doorbell count 0
NGIO-FC threshold XON/XOFF: 124699/137199, status: NGIO-XON, pause number: 0
XON packets: 0, XOFF packets: 0, refresh packets: 569224
outq HP1 traffic: packets 0, bytes 0, drops 0, error 0
outq HP2 traffic: packets 62534, bytes 24961614, drops 0, error 0
interface GE0
*******input*******
pkts: 503616800, bytes: 138913435255, drops: 0, error: 0, pause: 0
packets runt: 0, L2 giant: 0, crc: 0, jabber: 0, overrun: 0
ucast packets: 503548058, bytes: 136872797000
mcast packets: 68907, bytes: 26295211
bcast packets: 1, bytes: 60
*******output*******
pkts: 1160459298, bytes: 1313050758171, error: 0, pause: 0
underrun: 0, runt: 0, TxExcessColl: 0, TxDefer: 0
ucast packets: 1160390444, bytes: 1308004745077
mcast packets: 68978, bytes: 26260627
bcast packets: 2, bytes: 120
GMX Port Cfg: Speed [1000 mbps] Duplex [full-duplex] Slot-Time [4096 bit times(1000 mbps)] Link-En [True]
GMX Interface Mode: SERDES Speed rate [1.25 GBaud] Intf Speed [5 GBaud] Electrical Mode [XAUI] Pkt-intf-enable [Yes] intf-protocol-type [SGMII/1000Base-X]
Jabber limit [1528] Inter-frame cycles [0x8]
Pkt Tx Slot time:512 Burst:0x0
Pause Frames: Src-MAC 00bf7729d888 Dest-MAC 0180c2000001 tx-pause-type 0x8808 tx-pkt-time 0x708 tx-pkt-Interval 0x258
TX BP : Off, Tx-Ovr-BP=0
PCS Status: Link State [Up] Autoneg-capable [Yes] Remote-Fault [Yes]Preamble-suppression [Accepted]
Ok, thanks for the output.
Please provide the complete output to the following command:
sh license feature
