02-27-2012 10:57 AM - edited 03-04-2019 03:27 PM
Hello Guy's
We seem to be having an issue with one of our 4500's, our standby supervisor is continuously rebooting:
*Feb 27 09:47:29.387: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been detected
*Feb 27 09:47:44.891: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X4515 S/N: JAB071104QG Hw: 1.2) is online
*Feb 27 09:47:44.903: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for sso mode
*Feb 27 09:47:45.467: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
*Feb 27 09:47:52.919: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
*Feb 27 09:47:52.919: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
*Feb 27 09:47:52.923: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
*Feb 27 09:47:53.259: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Feb 27 09:47:56.275: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
*Feb 27 09:48:14.967: %ISSU-3-FAILED_TO_ALLOC_FUNCT_UNDER_ENTITY: Can not allocate ID32 space under client XDR Proc Priority ISSU client(2022) and entity(1)
-Traceback= 101C72D0 101C77FC 1029ACC0 102B2E88 102AB7AC 102A07F8 102ABB8C 102ABCE0 102AEC48 102AEE2C 10012BC8 102B399C 10F2425C 10010BC8 10010F70 1083D220
I have replaced the supervisor board but the issue still persists, hopefully this isnt a issue with the backplane but if someone could offer a suggestion it would help tremendously.
The key line seems to to be:
*Feb 27 09:48:14.967: %ISSU-3-FAILED_TO_ALLOC_FUNCT_UNDER_ENTITY: Can not allocate ID32 space under client XDR Proc Priority ISSUclient(2022) and entity(1)
Heres the redundancy cfg:
redundancy
mode sso
main-cpu
auto-sync startup-config
auto-sync config-register
auto-sync bootvar
auto-sync standard
Here is the output from the standby while booting up:
******** The system will autoboot now ********
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- bootflash:cat4500-entservices-mz.150-2.SG.bin
Rommon reg: 0x5F004380
k2diags version 5.7
prod: WS-X4515 part: 73-7785-06 serial: JAB071104QG
Power-on-self-test for Module 4: WS-X4515
Port/Test Status: (. = Pass, F = Fail, U = Untested)
Reset Reason: OtherSupervisor
Cpu Subsystem Tests ...
seeprom: . temperature_sensor: . eobc: .
Port Traffic: L2 Serdes Loopback ...
0: . 1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: .
12: . 13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: .
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: .
Port Traffic: L2 Asic Loopback ...
Port Traffic: L3 Asic Loopback ...
Switch Subsystem Memory ...
1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: . 12: .
13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: . 24: .
25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: . 36: .
37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: . 48: .
49: . 50: . 51: . 52: . 53: . 54: . 55: .
Netflow Services Card: WS-F4531 ...
se: . cf: . 56: . 57: . 58: . 59: . 60: . 61: . 62: . 63: . 64: . 65: .
66: . 67: . 68: . 69: .
Module 4 Passed
Exiting to ios...
Rommon reg: 0x5F000380
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 15.0(2)SG, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 26-Apr-11 15:25 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1219C7B0
Testing packet buffer memory: 00000 000000 000512 001024 001536 002048 002560 003072 003584 004096 004608 005120 005632 006144 006656 007168 007680 008192 008704 009216 009728 010240 010752 011264 011776 012288 012800 013312 013824 014336 014848 015360 015872 016384 016896 017408 017920 018432 018944 019456 019968 020480 020992 021504 022016 022528 023040 023552 024064 024576 025088 025600 026112 026624 027136 027648 028160 028672 029184 029696 030208 030720 031232 031744 032256 032768 033280 033792 034304 034816 035328 035840 036352 036864 037376 037888 038400 038912 039424 039936 040448 040960 041472 041984 042496 043008 043520 044032 044544 045056 045568 046080 046592 047104 047616 048128 048640 049152 049664 050176 050688 051200 051712 052224 052736 053248 053760 054272 054784 055296 055808 056320 056832 057344 057856 058368 058880 059392 059904 060416 060928 061440 061952 062464 062976 063488 064000 064512 065024 065536..done
All packet buffers passed.
* STANDBY SUPERVISOR *
* REDUNDANCY mode is SSO *
* Continue bootup *
cisco WS-C4507R+E (MPC8245) processor (revision 5) with 524288K bytes of memory.
Processor board ID FOX1438G559
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from Redundancy Reset
48 FastEthernet interfaces
100 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
* Welcome to Rom Monitor for WS-X4515 System. *
* Copyright (c) 2002 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor Program Version 12.1(12r)EW
Board type 2, Board revision 5
Swamp FPGA revision 24, Dagobah FPGA revision 95
MAC Address : 00-0a-41-c9-a9-ee
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Main Memory : 512 MBytes
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Again any suggestions?
Neil
02-27-2012 11:22 AM
Here's what I found on this error:
Error Message %ISSU-3-FAILED_TO_CREATE_ID32_SPACE: Failed to create ID32 space.
Explanation Failed to create ID32 space.
Recommended Action Enter the show proc mem or show buffs command to check if memory or buffer is full. Shuting down unused tasks or resetting cards usually can recover a memory leak problem. If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
02-29-2012 02:33 AM
Thank you, at least I know where to look.
02-27-2012 01:15 PM
Jake could be right. Initially the redundant supervisor crashes (I don't know why and that's another thing to investigate) and creates a crashlog. The supervisor continuously goes into this boot-crash-loop to the point that the bootflash gets full from the crashinfo file that it crashes some more. So you need to pull this blade out, erase all the crashlog and try again.
02-29-2012 03:35 AM
Hi thanks for you input,
During our maintance window I replaced the standby supervisor (original now back inplace), without success should i have performed a hard reboot on the active supervisor?
I am also not seeing any Crashfiles in the bootflash:
Here are some more log messages which I am reseaching:
Feb 29 03:16:55.496: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
*Feb 29 03:17:14.172: %ISSU-3-FAILED_TO_ALLOC_FUNCT_UNDER_ENTITY: Can not allocate ID32 space under client XDR Proc Priority ISSU client(2022) and entity(1)
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client XDR Process Priority Client absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client FIBHWIDB broker absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client FIBIDB broker absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client FIBHWIDB Subblock broker absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client FIBIDB Subblock broker absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client Adjacency update absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client IPv4 table broker absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:14.172: %XDR-6-ISSUCLIENTABSENT: XDR client CEF push absent on slot 4. Client functionality may be affected.
*Feb 29 03:17:15.636: %ISSU-3-BASE_CLIENT_CHECK_COMPATIBILITY: found at least one ISSU platform base client without compatible negotiation result
*Feb 29 03:17:15.640: %C4K_REDUNDANCY-3-PEER_RELOAD: The peer Supervisor is being reset because it failed during progression.
*Feb 29 03:17:16.612: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been lost
*Feb 29 03:17:16.624: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has been lost
Neil
02-29-2012 03:36 AM
show processes memory sorted
Processor Pool Total: 479652916 Used: 164454576 Free: 315198340
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 145937412 3498280 120224360 0 0 *Init*
0 0 2697817556 3238587556 23883916 1876136362 311186872 *Dead*
128 0 2007874728 311645132 7107316 689816460 34177576 IPC LC Message H
57 0 3321513832 3741266720 1051512 1307685824 1727760464 Cat4k Mgmt HiPri
12 0 783812868 3296966048 490864 2726143136 73117392 RF Slave Main Th
58 0 12055568 163032 409192 0 0 Cat4k Mgmt LoPri
241 0 87475512 87120284 402756 0 0 SNMP ENGINE
14 0 282564 1236 314584 0 0 ARP Input
193 0 239260 0 275184 99792 0 EEM ED Syslog
127 0 2627329676 548839204 263920 2023815936 163727512 XDR mcast
161 0 1442224 6776 251628 0 0 IP RIB Update
164 0 243360 204 248536 0 0 CEF: IPv4 proces
201 0 48980052 47650648 241220 0 0 EEM Server
30 0 961057708 408369832 206980 857292492 5357520 IPC Seat Manager
19 0 149968 479788 143604 0 96076 Entity MIB API
55 0 158292 180 131188 0 0 DHCPD Receive
184 0 228728 135396 113432 2340 0 VLAN Manager
49 0 3144047776 2007611140 111920 723427992 3398155880 cpf_msg_rcvq_pro
100 0 71308 0 104232 0 0 Switch Backup In
56 0 667799756 0 98988 0 0 Network-rf Notif
205 0 100192 24632 95720 0 0 Call Home proces
110 1 67932 47972 80780 0 0 Virtual Exec
109 0 656319360 358647976 80384 142128 0 CDP Protocol
183 0 2697428 4953828 68156 0 0 PM Callback
92 0 309720 47732 57844 0 0 DTP Protocol
1 0 927618516 3403126740 57240 0 0 Chunk Manager
148 0 1214404 9734840 53604 0 0 IGMPSN L2MCM
153 0 1213692 9673240 53468 0 0 MLDSN L2MCM
138 0 0 0 50924 0 0 COPS
11 0 0 0 50924 0 0 Crash writer
62 0 1131431812 191742540 48468 12756 0 RF Master Main T
236 0 11384 0 47308 0 0 BGP Scanner
143 0 13208 180 45952 0 0 REP BPA/EPA Proc
223 0 136112 30628 44316 50760 0 LACP Protocol
61 0 1749273276 204653868 44288 620834520 9388416 GalRedMsgProc
44 0 16700 65724 44164 2268 0 IF-MGR control p
32 0 446419352 133796896 43896 0 0 client_entity_se
4 0 68380 61540 43740 0 0 Deferred Events
210 0 7456 0 43380 0 0 EEM ED IOSWD
203 0 11696 1668 42952 0 0 EEM Policy Direc
69 0 854238232 3140895336 42332 0 1761647700 RedStateMonitor
160 0 5792 0 41716 0 0 IP Background
116 0 22778480 169680 41348 6726600 0 IP Input
204 0 102915072 102912804 41192 0 0 Syslog
215 0 5208 0 41132 0 0 EEM ED Timer
214 0 5056 0 40980 0 0 EEM ED SNMP
207 0 5044 0 40968 0 0 EEM ED CLI
213 0 5484 416 40960 0 0 EEM ED RF
194 0 4980 0 40904 0 0 EEM ED Routing
78 0 4980 0 40904 0 0 EEM ED MAT
217 0 4904 0 40828 0 0 EEM ED SNMP Noti
218 0 4904 0 40828 0 0 EEM ED Test
76 0 4904 297440796 40828 0 0 EEM ED ND
202 0 4904 0 40828 0 0 EEM ED RPC
208 0 4904 0 40828 0 0 EEM ED Counter
209 0 4904 0 40828 0 0 EEM ED Interface
77 0 4904 0 40828 0 0 EEM ED Identity
211 0 4904 0 40828 0 0 EEM ED None
212 0 4904 0 40828 0 0 EEM ED OIR
216 0 4904 0 40828 0 0 EEM ED SNMP Obje
221 0 4904 0 40828 0 0 EM ED GOLD
220 0 4904 0 40828 0 0 EEM ED Env
219 0 4904 0 40828 0 0 EEM ED Config
242 0 964 0 39888 0 0 IP SNMPV6
239 0 2583688448 2583682088 39824 0 0 IP SNMP
38 0 394368 16760 39536 254520 0 Net Background
190 0 504 368 39212 0 0 Collection proce
39 0 1240205236 1240204996 39164 0 0 IDB Work
115 0 420 204 39140 0 0 CEF switching ba
119 0 396 180 39140 0 0 ADJ resolve proc
124 0 420 4253708 39140 0 0 CEF background p
8 0 15960992 51991588 39120 13335960 41266672 Pool Manager
18 0 0 0 38924 0 0 Policy Manager
66 0 2006372760 0 38924 0 0 RFS server proce
40 0 180 180 38924 0 0 Logger
244 0 0 0 38924 0 0 SNMP Traps
243 0 0 0 38924 0 0 SNMP ConfCopyPro
85 0 180 10452 38924 0 0 Auth Manager
132 0 0 232704 38924 0 0 TCP Timer
133 0 45223092 13855584 38924 0 0 TCP Protocols
191 0 0 0 38924 0 0 Test AAA Client
79 0 180 180 38924 0 0 Ethernet CFM
80 0 180 180 38924 0 0 Ethernet Timer C
81 0 180 180 38924 0 0 Ethernet Msec Ti
240 0 8404 0 38924 0 0 PDU DISPATCHER
67 0 489766076 27954608 38332 371531256 1224576 RTTYS Process
46 0 216889516 115851784 37836 0 0 ISSU PROCESS IPC
135 0 1872 0 37796 0 0 HTTP CORE
47 0 219924772 122956676 37768 0 0 PrstVbl IPC Msg
140 0 4720 0 37644 0 0 Probe Input
112 0 4924 204 37644 0 0 AAA Dictionary R
234 0 116336 25928 36832 0 0 BGP Router
232 0 1060812 0 35976 0 0 BGP Scheduler
235 0 0 0 35924 0 0 BGP I/O
82 0 180 180 35924 0 0 Ethernet OAM Pro
222 0 0 0 35924 0 0 IPv6 RIB Event H
52 0 37930968 37019232 35924 0 0 IP Admission HA
41 0 428160 11348 35924 0 756 TTY Background
125 0 0 0 35924 0 0 IP IRDP
118 0 180 180 35924 0 0 IP ARP Track
50 0 278140544 180 35924 224416308 0 IP Host Track HA
99 0 180 180 35924 0 0 IP Host Track Pr
114 0 180 180 35924 0 0 EAPoUDP Process
157 0 2604 180 35348 0 0 L2TRACE SERVER
150 0 9468 5896 35016 0 0 IGMPSN
98 0 1900 180 34644 0 0 UDLD
172 0 1880 180 34624 0 0 LDAP process
174 0 1880 180 34624 0 0 TPLUS
6 0 455355060 429932528 34216 0 0 IPC ISSU Receive
63 0 4521392 736 33860 3648216 0 RF Master Status
51 0 20412652 23146292 33736 327240 0 ARP HA
3 0 15064392 0 33656 0 0 CEF RP IPC Backg
165 0 280 0 33204 0 0 ADJ background
87 0 10720 180 33192 0 0 Dot1x Mgr Proces
147 0 396 180 33140 0 0 Dot1x Supplicant
189 0 216 0 33140 0 0 DATA Collector
188 0 216 0 33140 0 0 DATA Transfer Pr
197 0 216 0 33140 0 0 Online Diag CNS
196 0 216 0 33140 0 0 Online Diag CNS
227 0 216 0 33140 0 0 DHCPD Database
182 0 209201480 209201808 33140 0 0 Online Diag EEM
146 0 396 180 33140 0 0 Dot1x Supplicant
145 0 396 180 33140 0 0 Dot1x Supplicant
123 0 14789188 180 33140 49140 0 Spanning Tree
96 0 216 0 33140 0 0 Port-Security
13 0 692507500 19607216 33132 4911060 0 ifIndex Receive
122 0 2055268 1582952 32968 0 0 SpanTree Helper
178 0 136 476 32968 0 0 DiagCard2/-1
224 0 0 0 32952 0 0 Call Home Timer
225 0 173844 0 32948 140316 0 GalRedConfSynPlf
106 0 0 0 32948 0 0 AAA System Acct
231 0 0 4680 32940 0 0 IP Flow Top Talk
130 0 15971044 15907828 32924 51024 0 XDR RP backgroun
131 0 0 0 32924 0 0 XDR RP Test Back
129 0 0 0 32924 0 0 XDR RP Ping Back
53 0 4280984 3095120 32924 25512 0 DHCPC HA
134 0 0 0 32924 0 0 Socket Timers
126 0 0 0 32924 0 0 AAA HA INT
136 0 180 180 32924 0 0 Cluster L2
137 0 0 0 32924 0 0 Cluster RARP
54 0 4132996 3006136 32924 0 0 DHCPD HA
139 0 0 0 32924 0 0 ECFM HA IPC flow
59 0 0 0 32924 0 0 Galios Reschedul
141 0 0 0 32924 0 0 RARP Input
142 0 180 180 32924 0 0 REP LSL Proc
60 0 0 0 32924 0 0 IOS ACL Helper
144 0 0 0 32924 0 0 Critical Auth
117 0 0 0 32924 0 0 ICMP event handl
64 0 0 0 32924 0 0 Net Input
113 0 0 0 32924 0 0 DHCP Snooping
48 0 2721462760 0 32924 537466768 0 cpf_msg_holdq_pr
149 0 6912 6912 32924 0 0 IGMPSN MRD
111 0 0 1464551952 32924 0 1159578104 cpf_process_tpQ
151 0 0 0 32924 0 0 IGMPQR
65 0 180 180 32924 0 0 Compute load avg
108 0 0 0 32924 0 0 IP Admin SM Proc
154 0 0 0 32924 0 0 MRD
155 0 0 0 32924 0 0 MLD_SNOOP
156 0 0 0 32924 0 0 RETRY_REPOPULATE
107 0 0 0 32924 0 0 Auth-proxy AAA B
158 0 0 0 32924 0 0 DHCP Snooping HA
105 0 0 0 32924 0 0 ACCT Periodic Pr
104 0 0 0 32924 0 0 AAA ACCT Proc
45 0 0 0 32924 0 0 IF-MGR event pro
162 0 0 0 32924 0 0 HSRP HA
163 0 211337140 211337140 32924 0 0 QoS stats proces
43 0 68484 3996 32924 55276 0 Per-minute Jobs
103 0 180 180 32924 0 0 AAA Server
166 0 0 0 32924 0 0 CFMPAL Process
167 0 0 0 32924 0 0 EPM MAIN PROCESS
168 0 0 0 32924 0 0 EM Background Pr
169 0 555084 160040 32924 0 0 LOCAL AAA
170 0 180 180 32924 0 0 ENABLE AAA
171 0 180 180 32924 0 0 LINE AAA
102 0 180 180 32924 0 0 Ethchnl
173 0 0 0 32924 0 0 EnergyWise incre
101 0 0 0 32924 0 0 MMN bkgrd proces
175 0 180 180 32924 0 0 REP Switch Helpe
176 0 180 180 32924 0 0 DHCP Security He
177 0 136 444 32924 0 0 DiagCard1/-1
68 0 36896876 33807684 32924 0 4252 IPC Apps Task
179 0 136 476 32924 0 0 DiagCard3/-1
180 0 0 300 32924 0 0 DiagCard4/-1
181 0 136 476 32924 0 0 DiagCard5/-1
97 0 180 180 32924 0 0 EFP Errd
42 0 4676 4676 32924 0 0 Per-Second Jobs
95 0 0 0 32924 0 0 PPCP RP Stats Ba
185 0 180 180 32924 0 0 dhcp snooping sw
186 0 180 8840 32924 0 0 VTP Trap Process
187 0 0 0 32924 0 0 SNMP Timers
94 0 0 0 32924 0 0 EAP Test
93 0 0 0 32924 0 0 EAP Framework
37 0 0 0 32924 0 0 Critical Bkgnd
91 0 0 65580 32924 0 0 802.1x switch
192 0 309120 1817864 32924 0 0 AAA SEND STOP EV
36 0 180 180 32924 0 0 GraphIt
35 0 0 0 32924 0 0 Dynamic ARP Insp
195 0 0 0 32924 0 0 Syslog Traps
90 0 0 0 32924 0 0 802.1x Webauth F
89 0 0 0 32924 0 0 AUTH POLICY Fram
198 0 180 180 32924 0 0 SPAN switch
199 0 0 0 32924 0 0 IP SLAs Ethernet
200 0 0 0 32924 0 0 IP SLAs AutoEthe
34 0 0 0 32924 0 0 ARP Snoop
33 0 0 0 32924 0 0 SERIAL A'detect
31 0 1164 1164 32924 0 0 PrstVbl
29 0 0 0 32924 0 0 IPC Deferred Por
28 0 0 0 32924 0 0 IPC Seat TX Cont
88 0 0 0 32924 0 0 MAB Framework
27 0 0 0 32924 0 0 IPC Managed Time
26 0 2485944 1540876 32924 1553256 962748 IPC Periodic Tim
25 0 0 0 32924 0 0 IPC Zone Manager
24 0 1231441160 0 32924 993438168 0 IPC Session Serv
23 0 0 0 32924 0 0 IPC Dynamic Cach
22 0 0 0 32924 0 0 IPC Mcast Pendin
21 0 0 0 32924 0 0 IPC Event Notifi
20 0 0 0 32924 0 0 IFS Agent Manage
17 0 180 180 32924 0 0 AAA high-capacit
16 0 0 0 32924 0 0 AAA_SERVER_DEADT
15 0 0 0 32924 0 0 CEF MIB API
86 0 180 180 32924 0 0 CMD HANDLER
10 0 180 180 32924 0 0 Serial Backgroun
9 0 180 180 32924 0 0 Timers
7 0 0 468 32924 0 0 Check heaps
84 0 180 180 32924 0 0 REP Topology cha
83 0 0 0 32924 0 0 PPPOE IA
71 0 0 0 32924 0 0 BACK CHECK
72 0 0 0 32924 0 0 AggMgr Process
226 0 0 0 32924 0 0 DHCPD Timer
73 0 0 0 32924 0 0 Transport Port A
75 0 0 0 32924 0 0 SFF8472
74 0 0 0 32924 0 0 HC Counter Timer
152 0 193819524 1480 32924 0 0 IGMPSN-HA
159 0 180 180 32924 0 0 ATIP_UDP_TSK
121 0 0 0 32924 0 0 IPv6 ping proces
5 0 0 0 32924 0 0 Retransmission o
237 0 0 0 32924 0 0 TCP Listener
120 0 420 204 30140 0 0 ADJ NSF process
2 0 180 180 29984 0 0 Load Meter
206 0 0 0 29924 0 0 System polling
70 0 0 0 27672 0 0 HA-IDB-SYNC
0 0 12248 2752120456 12248 0 0 *Sched*
230 0 29391212 27398288 11388 5076 0 OSPF-100 Router
228 0 1788 1854716 11156 0 0 OSPF-100 Hello
229 0 6556 24428 11116 0 0 OSPF-102 Hello
233 0 40368 99204 10128 0 0 OSPF-102 Router
164237576 Total
02-29-2012 03:58 AM
In order to resolve this leak, try to follow below procedure;
. Power down the switch
. Reseat both supervisors together
. Power on the switch
After that, if the two SUPs are detected normally, monitor memory
usage to see if leak happens again, in order to identify bugs related. You can check following logs for it:
. Show clock
. Show memory statistics
. Show proc memory sorted
Hope this helps,
Nik
