4507 - Loading new image upon reboot
sudip.acharya1
I have a 4507RE and just copied over a new IOS (cat4500-ipbase-mz.122-31.SGA11.bin). Since the older image is currently loaded, i need to reboot the switch so that the new image can be loaded. What command do I use to instruct the switch to use the new image and not old upon reboot? But i do not want to erase the old image just incase i need to revert back to it.
I have copied the Sh Vers and Sh Bootflash outputs below.
Thanks.
Nyo1#sh vers
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Versi
12.2(31)SGA6, RELEASE SOFTWARE (fc2)
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 32
Nyo1 uptime is 6 days, 4 hours, 8 minutes
Uptime for this control processor is 6 days, 4 hours, 8 minutes
System restarted at 21:46:54 UTC Tue Feb 23 2010
System image file is "bootflash:cat4500-ipbase-mz.122-31.SGA6.bin"
cisco WS-C4507R-E (MPC8245) processor (revision 14) with 524288K bytes of memo
Processor board ID FOX1247GU5W
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
7 Virtual Ethernet interfaces
24 FastEthernet interfaces
44 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
sh bootflas
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time---------
ame
1   .. image        03EDCAC2  C25744   33 12211908 Nov 29 2008 11:45:41 +00:00
2   .. config       08FF031E  C2637C    3     2999 Feb 1 2010 05:49:33 +00:00 u
t
3   .. image        23EDC87D 17B69C8   34 12125644 Feb 27 2010 01:27:58 +00:00
37000760 bytes available (24340936 bytes used)
Nyo1#
Leo Laohoo
conf t
no boot system
boot system bootflash:cat4500-ipbase-mz.122-31.SGA11.bin
boot system bootflash:cat4500-ipbase-mz.122-31.SGA6.bin
end
wr
reload
Basically, the commands mean boot SGA11 first.  If the IOS fails, boot SGA6.
Leo Laohoo
conf t
no boot system
end
wr
reload
Perfect.
Thanks for the rating.
