4507E WCCP Support
eToro_ISR
Hi Guys,
For some reason I don't have the WCCP feature on my 4507E Layer3 Switch.
What can be the cause of that?
This is my sh ver:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:19 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12C41C68
ROM: 12.2(44r)SG5
Darkside Revision 4, Nexu Revision 9, Fortooine Revision 1.22
ISR-SW-BACKBONE uptime is 48 weeks, 6 days, 20 hours, 6 minutes
Uptime for this control processor is 38 weeks, 1 hour, 1 minute
System returned to ROM by RPR Switchover
System restarted at 17:39:55 GMT Sun Mar 18 2012
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin"
Last reload reason: Unknown reason
cisco WS-C4507R-E (MPC8548) processor (revision 8) with 524288K bytes of memory.
Processor board ID FOX1445GBLK
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from Reload
21 Virtual Ethernet interfaces
112 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Reza Sharifi
It seems that your Sup does not support it:
from the config guide:
Catalyst 4900M, Catalyst 4948E, Supervisor Engine 6-E, and Supervisor Engine 6L-E do not support WCCP Version 2.
more info here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/wccp.html
Also your config-register should be 0x2102
Thank you for the quick reply!
Does GRE supported?
