Poor performance/packet loss with Cisco 887VA router on ADSL line
mitchen
Level 2
Level 2
We have a remote site connected to ADSL line with a Cisco 887VA router attached. This has been working fine for the last couple of months. However, recently, the site have started to complain of performance issues (network slow, applications disconnecting, etc)
Looking on the router, we can see evidence of packet loss/timeouts from a simple ping to the internet e.g.
ping 8.8.8.8 repeat 100
Sending 100, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 91 percent (91/100), round-trip min/avg/max = 36/38/60 ms
And looking at the “show controller vdsl 0” stats, the Noise Margin seems very low:
sh controller vdsl 0
Controller VDSL 0 is UP
Daemon Status:           Up
                       XTU-R (DS)             XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                  0x71BE
Chip Vendor Country:   0xB500                   0xB500
Modem Vendor ID:       'CSCO'                   '   '
Modem Vendor Specific: 0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FCZ1602C128 887VA-K9 15.1(4)M
Serial Number Far:
Modem Version Near:   15.1(4)M
Modem Version Far:     0x71be
Modem Status:           TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:           G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:     disabled
DELT state:             not running
Trellis:                 ON                       ON
Line Attenuation:       46.0 dB                 25.3 dB
Signal Attenuation:     46.0 dB                 25.6 dB
Noise Margin:             3.6 dB                 6.8 dB
Attainable Rate:       6856 kbits/s             1088 kbits/s
Actual Power:           18.5 dBm               12.8 dBm
Total FECS:             70880096                        608
Total ES:               22041                   44
Total SES:             22041                   0
Total LOSS:             0                       0
Total UAS:             0                       0
Total LPRS:             0                        0
Total LOFS:             0                       0
Total LOLS:             0                       0
Bit swap:               7946                     23
Full inits:             1
Failed full inits:     0
Short inits:           0
Failed short inits:     0
Firmware       Source         File Name (version)
VDSL           user config     flash:vdsl.bin.32bdslfw (10)
Modem FW Version:     101028_1158-4.02L.03.A2pv6C032b.d23b
Modem PHY Version:     A2pv6C032b.d23b
                 DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             5658             0             1062
Previous Speed:           0               0             0                0
Total Cells:             0       299125688             0         55976223
User Cells:               0         6570139             0           343547
Reed-Solomon EC:         0         70915190             0               608
CRC Errors:               0         1370201             0                 0
Header Errors:           0         6272974             0               77
Interleave (ms):       0.00             7.96         0.00             5.98
Actual INP:           0.00            1.01         0.00             0.46
However, we have logged the fault with our service provider and they return all line tests as clear but what is particularly strange is that they also report “and the SNR Margins are well within threshold levels (Upstream 11.5 and Downstream 15.0)” which, unless I’m misunderstanding something, seems to be completely different from what the router itself is reporting.
Is there a reason why the service provider’s stats for Noise Margin would appear to be so different from what the router is reporting?
And can anyone suggest any way we might a) identify the root cause of the issue and b) resolve it?
Thanks.
paolo bevilacqua
Circuit shows high attenuation and poor SNR.
Try another router if possible.
just to update on this one.  This has now been resolved after an engineer from the telco visited the site (we are told it was an "exchange fault" but not much more detail than that unfortunately.  We did not need to replace our router so it was definitely an issue on the telco side.  I believe the reason for the discrepancy between the noise margin reported by the Cisco router and that reported by the service provider was that they ran their diagnostics on the wrong line! (this ADSL line was in our office above the branch - they ran diagnostics against the branch connection)
Thanks for your input all the same.
