4948 TTL Expiry attack
semirke85
 Im looking for a way to mitigate TTL Expiry attack on a Cisco 4948-10G.
 I've been googling around for hours, however, havent yet found a way to do it :(
 Does anyone know a workaround to match low TTL packets?
 Currently routing low TTL packets and generating ICMP replies fully occupies the CPU :S
Thank you in advance!
Bests,
Semirke
More info:
The switch is running Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 15.0(2)SG9, RELEASE SOFTWARE (fc2)
when I try to add a TTL ACL, I got no such option:
me(config)#access-list 100 deny ip any any ?
  dscp        Match packets with given dscp value
  fragments   Check non-initial fragments
  log         Log matches against this entry
  log-input   Log matches against this entry, including input interface
  option      Match packets with given IP Options value
  precedence  Match packets with given precedence value
  time-range  Specify a time-range
  tos         Match packets with given TOS value
  <cr>
0 Replies 0
