4g Connectivity
DKer
Hi All,
I have a requirement to connect a temp 4g connection to a vlan. The current setup is 20 x Catalyst 9300 switch's connected back to a Catalyst 9500 all via fiber. Would it be possible to connect a 4g modem to a port on one of the 9300's and have internet connectivity across the network?
Thanks in Advance.
marce1000
 - In theory that is possible , if for instance a user ports is on the same vlan that the modem is plugged into (usually it will also provide dhcp), but is not a very solid and or a rather weak solution in terms of security.
 M.
marce1000
 M.
