4G LTE Backup Configuration to MPLS in router
Manas Dutta
I am trying to configure 4G LTE Verizon Backup via Cradlepoint modem connected to a MPLS  router for failover situations. The configuration that I have created is as follows :
ip sla 1
icmp-echo <neighbor-ip> source-ip <soource IP Address>
timeout 4000
threshold 1000
frequency 5
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
interface GigabitEthernet0/2
 description ### Connected to Wireless Modem ###
 ip address 192.168.250.250 255.255.255.0
 ip mobile router-service roam
 ip mobile router-service collocated gateway 192.168.250.250 ccoa-only
 ip tcp adjust-mss 1290
 duplex auto
 speed auto
 no routing dynamic
interface GigabitEthernet0/2.3900
 description ### Cradlepoint Mgmt VLAN ###
 encapsulation dot1Q 3900
 ip address 192.168.50.x 255.255.255.252
 ip mobile router-service roam priority 50
 no routing dynamic
router mobile
 distance 255
router bgp 65xxx
 network 192.168.50.0 mask 255.255.255.252
ip mobile secure home-agent (Verizon Public IP Address) spi decimal 256 key ascii VzWNeMo algorithm hmac-md5
ip mobile router
 address 1.2.3.4 255.255.255.0
 mobile-network G0/1
 mobile-network G0/2.3900
 register extend expire 10 retry 3 interval 5
 reverse-tunnel
 tunnel mode gre
route-map CLEAR-DF permit 10
 set ip df 0
int g0/1
 ip policy route-map CLEAR-DF
The LAN interface (G0/1) is running EIGRP with the LAN switch.
Let me know what you guys think.
busheyb
Was wondering if you ever came up with a solution?  I just starting to work on a similar situation so looking for any insite you might have.
Thanks in advance
