4G LTE cards - can I force attachment to a given cell site?
radiomean
Hi, I am experimenting with 4G LTE cards - both EHWIC-4G-LTE-GB and C887VAG-4G
The result of sh cell x radio gives me the following information about both the cell site the radio is attached to, and tells me three cell sites are detected and usable:
Idx          PCI (Physical Cell Id)
1                 252
2                 236
3                 334
I know that you can carry out a PLMN scan to detect all available networks and radio technologies, and can manually tell the modem to attach to a particular one of these (or use force mode, or auto). What I would also like to do is tell the modem to attach to a particular one of the three cells above - is this possible? I can't find any info on this...
Cheers, Bill
Felix Arrieta
Hello there,
https://www.cisco.com/c/en/us/td/docs/routers/access/900/software/configuration/guide/900SCG/4GLTE.html
Please review the link above (Selecting the Network) and test the following commands, those should be supported:
router#cellular <interface> lte plmn select manual ?
<0-999> Mobile Country Code (MCC)
router#cellular <interface>  lte plmn select manual 234 ?
<0-999> Mobile Network Code (MNC)
router#cellular <interface>  lte plmn select manual 234 10 ?
gsm GSM
lte LTE
umts UMTS
router#cellular <interface>  lte plmn select manual 234 10 gsm ?
permanent PERMANENT
power-cycle POWER_CYCLE
router#cellular <interface> lte plmn select manual 234 10 gsm power-cycle ?
<cr>
Hi and thanks... These commands force attachment to a particular carrier, as far as I can see - but I don't think they will force attachment to a particular cell site?
Cheers!
                         - I don't think the 4g-protocol has support for that,
 M.
