6500 Catalyst Switch - Query
Amin Shaikh
I would like to know how to enable timeout session for Cisco 6506 telnet session.. [ Issue is helpdesk login to 6506 and forget it close and the telnet session remains open... due to this after few sessions we are not alowed to telnet ]...
Collin Clark
6500#(config)service tcp-keepalives-in
6500#(config)service tcp-keepalives-out
6500#(config)line vty 0 15
6500#(config-line)exec timeout 5 0
This would timeout the connection after 5 minutes of idle time.
Hope that helps.
which only exec-timeout may be in some cases the connection remains open.. for more security configure absolute timeout in 60 minutes.
line vty 0 15
exec-timeout 5 0
absolute-timeout 60
Raul
Thank You for the input.
Can you expert help in configuring the box to ssh and I would like to enable NETFLOW to be used along with Solarwinds.
The 6500 is running CATOS
IOS (tm) MSFC3 Software (C6MSFC3-PSV-M), Version 12.2(14)SX2, EARLY DEPLOYMENT R
ELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 30-Jun-03 14:13 by cmong
Image text-base: 0x40008C10, data-base: 0x41A3A000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
CORESWITCH uptime is 10 weeks, 6 days, 20 hours, 14 minutes
System image file is "bootflash:c6msfc3-psv-mz.122-14.SX2.bin"
cisco MSFC3 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
34 Virtual Ethernet/IEEE 802.3 interface(s)
