6500 MSFC2 nbar problem
jheckart
Level 3
Level 3
I have a 6500 with redundant SUP2/MSFC2 runing hybrid. I setup a new SVI to connect a new VLAN to the network, and have been working great. I went ahead and enabled nbar protocol-discovery on the SVI, and started having some instability.
With nbar proto turned on, I began getting these messages in the logs of the sup every 2 minutes -
%SYS-5-MOD_OK:Module 16 is online
On the msfc, I had the following -
%SCP-4-DACK_TIMEOUT_MSG: SCP delivery ack timeout for opcode=15A
%RUNCFGSYNC-6-SYNCEVENT:
Non-Designated Router is now online
Running Configuration Synchronization will begin in 1 minute
Syncing Running Configuration to the Non-Designated Router
Syncing Startup Configuration to the Non-Designated Router
The msfc has c6msfc2-psv-mz.121-19.E1a.
Is this a bug in my ios version, or what?
Thanks.
Yes, it does look like this bug. The error messages, you posted, indicate the config doesn't sync up on the redundant MSFC and that triggers the software crash.
CSCec40719 Bug Details
Headline Using NBAR and SRM crashes redundant MSFC
Product IOS
Feature OTHERS Components Duplicate of
Severity 2 Severity help Status Resolved Status help
First Found-in Version 12.1(19)E01 All affected versions First Fixed-in Version 12.1(19.4)E01, 12.1(21.2)E, 12.2(17b)SXA, 12.1(20)EC, 12.1(21.4)EC Version help
Release Notes
A non-designated router (MSFC) in a catalyst 6500 running single-router-mode
(SRM) may fail to synchronize configuration with the designated router and
reload unexpectedly with a software-forced error if using network-based
application recognition (NBAR) in modular QoS when running 12.1(19)E1.
The workaround is to remove the class-maps that have 'match protocol'
configured, or revert back to 12.1(13)E10.
Sundar
Product IOS
Release Notes
Sundar
Thanks Sundar.
It's probably about time to upgrade the ios anyways.
