6500 switch boot problem
emadehsan
hi guys,
i have a 6509 with sup2.
i want to upgrade the IOS and Catos
but mail problem is when i changes the default pcmcia card with a high capacity pcmcia, the sup wont detect the new pcmcai.
i should say that my boorflash and slot0: dosent have sufficent memory.
regards
mohammedmahmoud
Level 11
Level 11
Hi Ehsan,
The Sup2 can have 16/24/64MB external flash, please do check the following documents for more details:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00801a5d58.shtml
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a0080116ff0.shtml
Flash Cards for the Catalyst 6500/6000 Supervisor Engine 1, 1A and 2 have minimum ROMMON, software version, and other requirements. Refer to Catalyst 6000 Family Flash Card Install Note:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_release_and_installation_notes09186a008026a74b.html
HTH,
Mohammed Mahmoud.
