6509 how do you shutdown a module prior to removing it?
evan2five
In order to remove a module I am not using in a 6509.
i attempted to run this command from global config mode. I think i might need to log into the IDSM-2 CLI ?
For Cisco IOS software:
hw-module module module_number shutdown
7 Replies 7
Jon Marshall
You should be able to shutdown the IDSM-2 module from the command line. I have used the command you tried many times on IDSM-2 and FWSM and it always worked but you don't run it from global config mode just from enable mode.
How are you verifying it has not worked. I run a "sh module" after issuing the command and the status should say "shutdown".
Jon
the command does not go in, comes back with unknown command and with the '^' pointer. I was attempting to run this in global config mode, not enable. Perhaps that was the issue?
If you are running IOS then yes, that will be your problem. You can only run this command from enable mode. After running it you can run a "sh module" and look at the status of the relevant module.
Jon
or you can run this command with "do" prefix. Like: "do hw-module module module_number shutdown". "Do" executes ENABLE mode commands from CONFIG mode
Wilson Samuel
Level 7
Level 7
If you have physicall access to the switch, you may choose the shutdown "button" on the module to bring the module down.
Kind Regards,
Wilson Samuel
thanks guys, got this sorted.
Paul Murray
To powerdown module 8, in conf t mode type:
no power enable module 8
You'll need get a status as below of PwrDown:
  8  Distributed Forwarding Card WS-F6700-DFC3C     SAL14491WAE  1.4    PwrDown
