6509 IOS Routing Path
vtra
Using 6509 attached to muliple firewalls leading to different destinations.  I'm in a new environment and have no knowledge of their layout.
Is there a way to find out what path the packets are taking?
In the past, I would do a "Sh ip int brief"
List of vlan is displayed with ip address.
I usually do a "traceroute" from one of these sources to find the path that it is taking to a destination.  However, in this cases icmp is blocked by firewall.
The default gateway on these server point to the router and not firewall. I have no access to the server.
Example.
Given server "aaa" ip info, and it's targeted destination, how can i tell if its passing through firewall a or firewall b?  Besides the method above, I'm thinking of doing "sh ip route xx.xx.xx.xx" the "Last update from 10.129.12.9 on Vlan312, 2d07h ago" is the default gateway right?
CORE1#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
  Known via "ospf 129", distance 110, metric 2, candidate default path
  Tag 141049920, type extern 1
  Routing Descriptor Blocks:
  * 10.129.12.9, from 12.149.44.148, 2d07h ago, via Vlan312
      Route metric is 2, traffic share count is 1
      Route tag 141049920
Thank you for the Assistance
Edison Ortiz
