6807-XL Sup6T problems (after running diagnostic)
m-avramidis
After running diagnostic start system test all and reloading the entire chassi  the non-supervisors modules does not power up. If running the command:"(config)#power enable module X" some but not all of the modules comes up online (different each time). After reloading the entire chassi a couple of
times then all modules comes on-line again.
Have tried 4 different chassis (using the 4 different SUP6T), with the same result. Softare used: 15.3.1-SY2 and 15.5.1-SY1
Also, the test takes about 2-3 hrs to complete....I run the same test using the same chassis but with SUP2T (15.2.1-SY5) the entire test took 1 hour, all modules came back on-line after reloading the switch.
Have anyone experienced this problem? If so, how did you fixed this problem?
0 Replies 0
