6xCat375V2 Stack - Losing packets.
ALEXANDR LYKOV
Frequent Visitor
Frequent Visitor
Hi!
We'd had 5 switches in the stack and everything was ok. but then we connected a new 6th switch so I can see periodical short loosing packets. It happened on many hosts connected to these stack at different time. Cpu load is ok and no any errors in logs. Any others debugs?
(From my host)
ping -t 10.8.8.xx
Reply from 10.8.8.xx: bytes=32 time<1ms TTL=127
Request timeout
Request timeout
From this switch (vlan int)
SW01#ping 10.8.8.45 repeat 100000
Switch Ports Model              SW Version            SW Image
     1 52    WS-C3750V2-48TS    12.2(58)SE2           C3750-IPSERVICESK9-M
*    2 52    WS-C3750V2-48TS    12.2(58)SE2           C3750-IPSERVICESK9-M
     3 52    WS-C3750V2-48TS    12.2(58)SE2           C3750-IPSERVICESK9-M
     4 52    WS-C3750V2-48PS    12.2(58)SE2           C3750-IPSERVICESK9-M
     5 52    WS-C3750V2-48TS    12.2(58)SE2           C3750-IPSERVICESK9-M
     6 52    WS-C3750V2-48TS    12.2(58)SE2           C3750-IPSERVICESK9-M
SW01#sh switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
    3           Ok           Ok
    4           Ok           Ok
    5           Ok           Ok
    6           Ok           Ok
SW01#sh switch stack-ring speed
Stack Ring Speed        : 32G
Stack Ring Configuration: Full
Stack Ring Protocol     : StackWise
ALEXANDR LYKOV
Frequent Visitor
Frequent Visitor
only L2 switching. no routing.
Were taken into account the recommendations of this article?
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
So can you print here Traceroute for 10.8.8.xx
The problem arises in the entire switch or specifically in hosts sitting on the 6th switch?
----------------------------------------------------------- Прошу вас оценивать и отмечать полезные для вас сообщения. Please rate helpful answers.
Solved. CPU load was not OK on some switches in stack.
There was high Port-security load.
I had this config:
interface FastEthernet x/x/x
switchport access vlan 128
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
macro description cisco-phone | cisco-phone | cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQoS-Police-CiscoPhone
end
now I've changed it adding this:
switchport port-security aging time 5
switchport port-security aging type inactivity
