12-15-2006 09:05 AM - edited 03-03-2019 03:03 PM
Kndly;what does it mean this in Detail;when i did sh ip route:
170.100.0.0/16 is variably subnetted,7 subnets,2 mask.
12-15-2006 09:10 AM
ali
That indicates that within the routing table there are 7 subnets of network 170.100.0.0. It indicates that as a nominal class B network the natural mask for network 170.100.0.0 is /16 (or 255.255.0.0). And it indicates that the 7 subnets do not all use the same subnet mask (so it is variable subnetted) and that 2 different subnet masks are used for subnets within that network.
For example you might find that some of the subnets within network 170.100.0.0 are /24 (or 255.255.255.0) for user subnets and that other subnets are /30 (or 255.255.255.252) for point to point links.
Rick
12-15-2006 09:36 AM
Hi Rburts!
i missed ur great explanation;u have won my 5 points.10xs a lot for ur usefull reply
Ali
12-15-2006 09:50 AM
Ali
I am glad that my explanation was helpful.
Thanks for the kind words and the rating.
Rick
12-15-2006 09:49 AM
Hi rick;here u 5 points;10xs alot...
