Reset Default Config thru CLI on 1841
mitchell.smith
I need to restore the routers default configuration and the SDM is corrupt, can you tell me how to do this thru CLI? Thanks!
Try using command,
Copy flash:SDM_Backup startup-config
-amit singh
amit-singh
Level 8
Level 8
Do the following:
router# erase nvram:
router#reload
HTH,
-amit singh
Hi Amit,
This did clear the config back to default, but what I really need is the default SDM configuration that is sitting in flash. How do I copy this config from flash to NVRAM?
Here is my flash directory:
Router#show flash
-#- --length-- -----date/time------ path
1 24967872 Oct 17 2006 16:46:40 +00:00 c1841-advipservicesk9-mz.124-3f.bin
2 1821 Oct 17 2006 17:01:40 +00:00 sdmconfig-18xx.cfg
3 4734464 Oct 17 2006 17:02:22 +00:00 sdm.tar
4 833024 Oct 17 2006 17:02:48 +00:00 es.tar
5 1052160 Oct 17 2006 17:03:14 +00:00 common.tar
6 1038 Oct 17 2006 17:03:36 +00:00 home.shtml
7 102400 Oct 17 2006 17:04:00 +00:00 home.tar
8 491213 Oct 17 2006 17:04:22 +00:00 128MB.sdf
9 1684577 Oct 17 2006 17:05:00 +00:00 securedesktop-ios-3.1.1.27-k9.pkg
10 398305 Oct 17 2006 17:05:32 +00:00 sslclient-win-1.1.0.154.pkg
11 14616 Dec 13 2006 20:58:22 +00:00 SDM_Backup
Mitchell
I have not had to do this so can not speak from experience. But it looks to me like the file is flash: sdmconfig-18xx.cfg is what you need. When you erased nvram you left the router with a very empty config - including no SDM. I believe that this file from flash will have the SDM config that you need.
Rick
Rick
Try using command,
-amit singh
