7200 Not working
My Router cisco 7200 series is haveing problem. When i finish the config on the g0/1 service as my Outside interface with a public Ip address and g0/2 ad inside with a private Ip, the router hangs and I change the g0/2 to g0/3 and it's still the same problem. when pinging it will reply while loading the IOS file but immediately it finish loading it will time out. Please Help me give a lasting solution to this. Thank You
paolo bevilacqua
Which exact IOS do you have ?
Thanks for Replying my message. My IOS version 12.2.
That can be sw bug, if you are ok with 12.2 pls upgrade, I suggest 12.2(46a).
Thanks please Can You help me with a direct link were i can get that downloaded. Thank you.
