7200 with VTI ipsec issues
We have a Cisco 7204 G1 running c7200-advipservicesk9-mz.122-33.SRE7.bin and we're having a lot of difficulties getting a VTI working to a Cisco 2921 with adv. security.
I've ruled out that the 2921 is at fault by successfully establishing a VTI to another 2921 and a 7200 running a different IOS release.
We see the tunnel come up, but when I sent a ping from the 2921 to the 7204 there isn't a reply.
When I look at the results on the 7204 from a 'sh crypto engin connection active', I see the decrypt counters increase, but I don't see the Encrypt counters increase as it's trying to reply to the ping.  I'm not sure if this is because there is an issue with the encryption or wheather there might be a more fundemental issue with the router not replying to the pings.
I've tried the following IOS releases (c7200-advipservicesk9-mz.122-33.SRE7 & c7200-advipservicesk9-mz.122-33.SRE6) and they all behave the same way - this makes me think it might be a config issue rather than and IOS bug which is what I first thought.
sh crypto engine connections active
Crypto Engine Connections
   ID Interface       Type  Algorithm           Encrypt  Decrypt IP-Address
    1 Tu10            IPsec 3DES+SHA                  0       31 10.5.5.1
    2 Tu10            IPsec 3DES+SHA                 19        0 10.5.5.1
1001 Tu10            IKE   SHA+3DES                  0        0 10.5.5.1
Here is a copy of my config on the 7204 - the other end (Cisco 2921) is configured in the same way
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxxxxx address 192.168.5.1
crypto ipsec transform-set 3DESSHA esp-3des esp-sha-hmac
crypto ipsec profile IPSEC-VPN
set transform-set 3DESSHA
interface Loopback10
ip address 10.5.5.1 255.255.255.255
interface Tunnel10
ip address 10.10.10.1 255.255.255.252
tunnel source Loopback10
tunnel mode ipsec ipv4
tunnel destination 192.168.5.1
tunnel protection ipsec profile IPSEC-VPN
Any assistance would be greatly appreciated.
Jonathan.
16 Replies 16
I forgot to mention that I'm sending the ping traffic from router to router - pinging the remote end of the tunnel.
Jonathan
I do not see an obvious issue in the part of the config that you posted. So we need to dig a bit deeper in looking for the cause of the problem.  Can you post the following outputs for the 7200:
- show ip interface brief
- show crypto ipsec sa
- traceroute 192.168.5.1
Rick
Rick
Hi Rick,
Thanks for your reply.
Here's output from the commands you requested.
sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/1     unassigned      YES NVRAM  up                    up
GigabitEthernet0/1.43  x.x.x.x         YES NVRAM  up                    up
GigabitEthernet0/2     unassigned      YES NVRAM  up                    up
GigabitEthernet0/2.42  x.x.x.x         YES NVRAM  up                    up
GigabitEthernet0/3     unassigned      YES NVRAM  administratively down down
Loopback0              x.x.x.x         YES NVRAM  up                    up
Loopback10             10.5.5.1        YES NVRAM  up                    up
Tunnel10               10.10.10.1      YES NVRAM  up                    up
Tracing the route to 1-38-17-10.static.test.com (192.168.5.1)
  1 62-60-17-10.static.test.com (10.17.60.62) [MPLS: Label 660 Exp 0] 16 msec 12 msec 12 msec
  2 81-60-17-10.static.test.com (10.17.60.81) [MPLS: Label 396 Exp 0] 12 msec 12 msec 12 msec
  3 81-63-17-10.static.test.com (10.17.63.81) [MPLS: Label 694 Exp 0] 12 msec 12 msec 12 msec
  4 129-63-17-10.static.test.com (10.17.63.129) 12 msec 12 msec 12 msec
  5 34-37-17-10.static.test.com (10.17.37.34) 28 msec *  24 msec
#sh crypto ipsec sa
interface: Tunnel10
    Crypto map tag: Tunnel10-head-0, local addr  10.5.5.1
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   current_peer 192.168.5.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 66, #pkts encrypt: 66, #pkts digest: 66
    #pkts decaps: 116, #pkts decrypt: 116, #pkts verify: 116
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.:  10.5.5.1 , remote crypto endpt.: 192.168.5.1
     path mtu 1514, ip mtu 1514
     current outbound spi: 0x417F00DA(1098842330)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0xA0613593(2690725267)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 37, flow_id: 37, sibling flags 80000040,  crypto map: Tunnel10-head-0
        sa timing: remaining key lifetime (k/sec): (4469938/1859)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 38, flow_id: 38, sibling flags 80000040,  crypto map: Tunnel10-head-0
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
Jonathan
Jonathan
Thank you for the outputs that I requested. I find them encouraging. If these are from the 7200 it might be helpful to see the same outputs from the 2921.
What I am seeing in these outputs seems to confirm that the tunnel is working ok. In particular I note these points:
- one requirement for VTI tunnels is that there is IP connectivity between the tunnel source and the tunnel destination. The traceroute does seem to demonstrate that this connectivity does exist.
- one of the requirements for the VTI tunnel to come up an up/up state is that the crypto negotiation was successful. The fact that the tunnel does show as up/up confirms that there is crypto negotiation.
- in the IPSec Security Association the counters for encrypted and decrypted are both non-zero and this indicates that there is two way traffic flowing through the tunnel.
I would like to request one more output from the 7200. Please post the output of show ip route 10.10.10.2
If the tunnel seems to be working but the ping is not working them there must be some other cause of the problem other than something wrong with the tunnel. Perhaps you can post the configuration of the 2921? And while I am asking for things perhaps also the same outputs from the 2921 that I requested from the 7200?
Rick
Rick
Hi Rick,
Here is the output you requested.  Something to note, when the IPSec config from the tunnel is removed (so it becomes a standard gre tunnel) traffic goes through without a problem.
Show ip route from the 7200
sh ip route 10.10.10.2
Routing entry for 10.10.10.0/30
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Redistributing via ospf 10
  Advertised by ospf 10 subnets
  Routing Descriptor Blocks:
  * directly connected, via Tunnel10
      Route metric is 0, traffic share count is 1
version 15.1
no service pad
service password-encryption
hostname 2921
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-4.M4.bin
boot system flash:c2900-universalk9-mz.SPA.151-4.M3.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
no ip source-route
ip cef
no ip domain lookup
encr 3des
group 2
crypto isakmp key xxxxxxx address 10.5.5.1
interface Loopback0
description Source interface for tunnel to backoffice
ip address 192.168.5.1 255.255.255.255
interface Tunnel10
description tunel to 7200
ip address 10.10.10.2 255.255.255.252
tunnel source loopback0
tunnel destination 10.5.5.1
interface GigabitEthernet0/0
no ip address
shutdown
duplex full
speed 1000
interface GigabitEthernet0/1
description Fiber to upstream
ip address 10.17.37.34 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
description LAN network
ip address 10.17.37.1 255.255.255.224
duplex auto
speed auto
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.17.37.33 250
sh ip int brief
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         unassigned      YES manual administratively down down
GigabitEthernet0/1         10.17.37.34     YES manual up                    up
GigabitEthernet0/2         10.17.37.1      YES NVRAM  up                    up
Loopback0                  192.168.5.1     YES NVRAM  up                    up
Tunnel10                   10.10.10.2      YES manual up                    up
interface: Tunnel10
    Crypto map tag: Tunnel10-head-0, local addr 192.168.5.1
   current_peer 10.5.5.1 port 500
    #pkts encaps: 136, #pkts encrypt: 136, #pkts digest: 136
    #pkts decaps: 86, #pkts decrypt: 86, #pkts verify: 86
     local crypto endpt.: 192.168.5.1, remote crypto endpt.: 10.5.5.1
     path mtu 1514, ip mtu 1514, ip mtu idb Loopback0
     current outbound spi: 0x965C2BDA(2522622938)
     inbound esp sas:
      spi: 0x65D51986(1708464518)
        conn id: 2087, flow_id: Onboard VPN:87, sibling_flags 80000046, crypto map: Tunnel10-head-0
        sa timing: remaining key lifetime (k/sec): (4554753/1417)
        IV size: 8 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2088, flow_id: Onboard VPN:88, sibling_flags 80000046, crypto map: Tunnel10-head-0
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
traceroute 10.5.5.1
Tracing the route to 10.5.5.1
  1 10.17.37.33  12 msec 12 msec 12 msec
  2 10.17.63.141  28 msec 24 msec 24 msec
  3 10.17.63.86  24 msec 24 msec 24 msec
  4 10.17.60.82  24 msec 28 msec 24 msec
  5 10.17.60.49  24 msec *  24 msec
Many thanks,
Jonathan
Jonathan
Thanks for these outputs. They seem to confirm that the tunnel is working ok. Unfortunately they do not suggest what the problem is that is preventing ping to the other end of the tunnel.
So I will suggest an additional test. Please enable debug ip icmp on both routers. then ping from one router to the other. capture the debug output and post it. I note that the 2921 sets the logging level for logging buffered to warning and I wonder if the 7200 does this also. Either you need to have active sessions to the router (and verify that the logging level for monitor is set to debug) or you need to change the configured logging buffered level to debug.
It might be a better test to do ping from each of the routers and to mark in the debug output which is which.
Rick
Rick
Hi Richard,
Here the output from the 2921 when I send 5 pings from the 7200
May 22 23:25:36.987: ICMP: echo reply sent, src 10.10.10.2, dst 10.10.10.1, topology BASE, dscp 0 topoid0
May 22 23:25:38.987: ICMP: echo reply sent, src 10.10.10.2, dst 10.10.10.1, topology BASE, dscp 0 topoid0
May 22 23:25:40.987: ICMP: echo reply sent, src 10.10.10.2, dst 10.10.10.1, topology BASE, dscp 0 topoid0
May 22 23:25:42.987: ICMP: echo reply sent, src 10.10.10.2, dst 10.10.10.1, topology BASE, dscp 0 topoid0
May 22 23:25:44.987: ICMP: echo reply sent, src 10.10.10.2, dst 10.10.10.1, topology BASE, dscp 0 topoid0
When I do the same from the 2921 back to the 7200 I get no debug output at all....
But, I'm quite sure they arrive and are 'seen' by the router at some level because the Decrypt counters increase while pings are being sent.
   45 Tu10            IPsec 3DES+SHA                  0       73 10.5.5.1
   46 Tu10            IPsec 3DES+SHA                  5        0 10.5.5.1
1003 Tu10            IKE   SHA+3DES                  0        0 10.5.5.1
72001#sh crypto engine connections active
7200#sh crypto engine connections active
   45 Tu10            IPsec 3DES+SHA                  0       74 10.5.5.1
Jonathan
Jonathan
Can you verify that debug is enabled on the 7200 and that logging is enabled at the level of debug and try the ping from the 2921 again? and post whether there is any debug output?
Rick
Rick
Hi Rick,
Yes, logging is enabled on the 7200, I received some icmp debug from our monitoring system that is sending pings to the 7200 - but nothing from the 2921.
Jonathan
Jonathan
That is quite puzzling.
Please post the output from the 2921 of show ip route 10.10.10.1
My second suggestion is to configure some other address on the 7200 (perhaps some other physical interface or perhaps another loopback interface) and then on the 2921 configure a static route that says you can get to the 7200 other address via the next hop through the tunnel. Then ping and traceroute to that address from the 2921.
My third suggestion is to configure a routing protocol (perhaps EIGRP) and configure it to run over the tunnel. It does not necessarily need to advertise other subnets yet, but I would like to see whether it is able to establish neighbor relationships over the tunnel.
Rick
Rick
Hi Rick,
I agree it's very puzzling....
Here is the output of the sh ip route command from the 2921
sh ip route 10.10.10.1
When I add the static route I don't get a reply to pings and a traceroute gives the following output:
Tracing the route to 10.17.60.252
VRF info: (vrf in name/id, vrf out name/id)
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *
I configured ospf on both sides.  The 2921 tied to bring it up, but stayed in the 'INIT' state.
The 7200 sends 'hello' packets, and I see these get to the 2921, but, the 7200 never gets the hello messages from the 2921.  This is the same behaviour that we see with the icmp debug.
Jonathan
Jonathan
This feels very much like there is some routing issue involved, and most likely on the 7200. You have given us some (but not all) of the config of the 2921 and very little of the config of the 7200. I wonder if there is some clue to the issue  in the parts of the config that you have not yet posted. Can you give us some more of the config?
Perhaps the output of show ip route from the 7200 might give us some clue. Also perhaps the output of show ip protocol.
I am also wondering about what is running on the 7204. Perhaps you can post the output of show version?
Most of the 7200 that I have experience with were running 12.3 or 12.4 versions. You indicate that it is running c7200-advipservicesk9-mz.122-33.SRE7.bin. 12.2(33)SRE7 seems unusual to me. I will do some looking about that. If there is anything that you can give us about the code that you are running might be helpful.
Rick
Rick
Jonathan
I am finding it difficult to find good information. But what I am finding suggests that what you have is the ubr7204, which is a router for cable modem termination systems and not the general purpose 7204 that i was assuming that you were using. What I am seeing suggests that VTI is not supported in that platform. In fact I am surprised that the commands to configure it were accepted, if I am correct about your platform. So I am waiting for the show version and any other information that you can provide about the details of the platform that you are using.
Rick
Rick
Jonathan
I just found a reference in the Cisco Feature Navigator that says that VTI is supported in the version of code that you are running. So now I am quite confused. But I am leaning toward it being buggy behavior in the IOS.
Rick
Rick
