7204 router RAIDUS issue
Andrew Schulz
I was attempting to setup our 7204 Cisco router to use RADIUS for authentication via the AAA commands. I must have messed up when configuring it as it comes up via TELNET asking for a username and password but doesn't take my AD credentials. How might I login to this router to fix the config? Do I need to do a password recover process?
One note, I didn't save the running-config to startup-config, so if I restart the router will it load the startup-config, thus overwriting the running-config that wasn't working?
wzhang
Yes a reload would help you recover from the lockout. That's rule #1 when configuring AAA - you don't write the config until you can verify AAA is working with and without connectivity to the AAA server.
Wen
wzhang
Wen
Thanks for confirming that Wen. I'll give it a restart.
