7204 vxr lacp problem
voiptrader
Hi have a problem with the LACP implementatio in a 7204VXR.
I cannot find the LACP commands.
Here the SHOW VER:
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(21), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 11:36 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-BOOT-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
I need to combine two gigabitethernet interfaces with LACP but i can't find any lacp commands in my IOS.
Should I update my IOS ? to wich version?
Now my 7204 vxr has the IOS release 12.4(21) and it contains the feature Link  Aggregation Control Protocol (LACP) (802.3ad) for Gigabit Interfaces, so i should be able to use LACP command!
Focusing on the problem: I'm reading the Cisco's document "Configuring  IEEE 802.3ad Link Bundling and Load Balancing"
Enabling LACP
SUMMARY STEPS
1. enable
2. configure terminal
3. interface port-channel channel-number
4. channel-group channel-group-number mode {active | passive}
5. end
In step 4 i have to use the channel-group command but in the port-cahennel interface config i haven't this type of command.
Associating a Channel Group with a Port  Channel
SUMMARY STEPS
1. enable
4. interface type number
5. channel-group channel-group-number mode {active | passive}
6. end
In step 6 I have to use channel-group command but in the gigabitEthernet interface config this command doesn't allow to add the parameter mode {active | passive}
Also i have to use a lot of lacp command that i can't find in any configure mode:
lacp system-priority priority
show lacp sys-id
lacp min-bundle min-bundle
show lacp {number | counters | internal | neighbor | sys-id}
lacp direct-loadswap
Any suggestion?
Thanks to everybody
Max
Jibran Aziz
Did you find solution to it? I've googled alot, could not get any such IOS of 7200 series which supports LACP.
Jib
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA | CWNA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
