7204VXR Question
adam_dyer
Does anyone have any experience with the bandwidth points limits on the 7204?  The documentation says to limit to only 600 points per bus.  This really limits this router as far as fast ethernet interfaces is concerned.  Has anyone loaded theirs above this limit?  What kind of performance did you get out of the router?
Thanks for your help.
Nagaraja Thanthry
I believe when you exceed the bandwidth points, the router disables some modules. Here is a document on bandwidth calculation:
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_presentation09186a008009184d.pdf
Hope this helps.
NT
