Simple Routing Issue
Carl Williams
Hi All
I've configured a network with PE's and CE's what I have is EIGRP running between PE's and EBGP between PE and CE's. can't reach router loopback address of other CE's. Routing on the PE's works to all locations without a problem. I have DMVPN running between PE's but this is'nt impacting the routing in anyway because the PE's can reach other and all LAN and loopback subnets.
Between CE and PE i redistribute EIGRP into BGP and BGP into EIGRP.
The problem seems to be the routing between CE-CE.
Exampls
ping from
CE1-CE3
CE-1-CE2
from CE-1 pinging loopback 192.168.3.1
from CE-1 pinging loopback 192.168.10.1
All other routing works well.
Can anyone point me in the right direction configurations attached,
All i need is to have full routing from the CE's. I don't know why the PE's are dropping packets destined for other CE's.
Please find configs attached.
Carl Williams
missing config...
