7204vxr will not recognize a pa-pos-2oc3 card
When the router boots up, the boot loader keeps telling me it does not recognize the card and wait until it fully boots to see the revision on the card, but I can not see the revision on the card because it is unrecognized.
Does anyone know what boot loader I need to get the 7204 to recognize the card?
IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 19:27 by dchih
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.3(8)ZA1, RELEASE SOFTWARE (fc2)
Router uptime is 0 minutes
System image file is "disk2:/c7200-js-mz.123-26.bin"
cisco 7204VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 16061434
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.0
Thank you
Matt
5 Replies 5
Reza Sharifi
The 2-Port OC-3/STM-1 POS Port Adapter is supported in Cisco IOS®  Software Release 12.2(13)ZE, 12.3, 12.3T, 12.2S(RLS3), 12.0(27)S, and  later. Consult your Cisco representative for more details.
You may want to upgrade to one of these revisions and see if the card gets recognized.
http://www.cisco.com/en/US/prod/collateral/routers/ps341/product_data_sheet09186a0080145f66_ps2033_Products_Data_Sheet.html
That is what baffles me, I checked to make sure my IOS was actually newer than required and no dice?
Your IOS is not newer than what has been correctly indicated to you above. You need to update to one of the correct release.
I am confused then, my boot loader is 12.3(8)ZA1, is that not newer than 12.2(13)ZE, 12.3, 12.3T, 12.2S(RLS3), 12.0(27)S?
If not can you tell me was is?  12.4 of any kind?
Forget about the bood loader.
You need to update IOS image.
