7206 G1 boot issue: No interface specified for interface_command
bigalwhite
Community Member
I can't seem to find out what this command means? I am pasting a config into a new router, do I need to paste in a certain order?
It boots just fine after it decompresses again, but it leaves me with a very lengthy boot time.
Core_7206_1#write mem
Building configuration...
[OK]
Core_7206_1#reload
Proceed with reload? [confirm]
*Jun  7 01:16:43.547: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
C7200 platform with 1048576 Kbytes of main memory
Readonly ROMMON initialized
Self decompressing the image : ########################################################################### [OK]
% No interface specified for interface_command
% Cannot set multilink group. Interface Multilink2 does not exist
% Cannot set multilink group. Interface Multilink9 does not exist
% Cannot set multilink group. Interface Multilink10 does not exist
% Cannot set multilink group. Interface Multilink3 does not exist
% Cannot set multilink group. Interface Multilink7 does not exist
% Cannot set multilink group. Interface Multilink4 does not exist
% Cannot set multilink group. Interface Multilink5 does not exist
% Cannot set multilink group. Interface Multilink8 does not exist
% Cannot set multilink group. Interface Multilink11 does not exist
% Cannot set multilink group. Interface Multilink6 does not exist
% Cannot set multilink group. Interface Multilink12 does not exist
Self decompressing the image : ###################################################################################################################################################################################################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Aug-08 03:06 by prod_rel_team
Image text-base: 0x600089D8, data-base: 0x632911A0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 31651452
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 90 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 490 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
2 FastEthernet interfaces
3 Gigabit Ethernet interfaces
4 Channelized T1/PRI ports
2 Channelized T3 ports
509K bytes of NVRAM.
Installed image archive
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Press RETURN to get started!
*Jun  7 01:21:56.191: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Jun  7 01:21:56.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun  7 01:21:56.195: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Jun  7 01:21:56.195: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
*Jun  7 01:21:56.199: %LINK-3-UPDOWN: Interface T3 1/0, changed state to down
*Jun  7 01:21:56.199: %LINK-3-UPDOWN: Interface T3 2/0, changed state to down
*Jun  7 01:21:56.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface IPv6-mpls, changed state to up
*Jun  7 01:21:56.199: %LINK-3-UPDOWN: Interface FastEthernet4/0, changed state to down
*Jun  7 01:21:56.199: %LINK-3-UPDOWN: Interface FastEthernet4/1, changed state to down
*Jun  7 01:21:56.199: %ENVM-4-ENVWARN: NPE Inlet measured at 54C/129F
*Jun  7 01:21:56.207: %ENVM-4-ENVWARN: NPE Outlet measured at 54C/129F
*Jun  7 01:21:56.535: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:21:56 UTC Mon Jun 7 2004 to 20:21:56 GMT Sun Jun 6 2004, configured from console by console.
*Jun  7 01:21:57.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Jun  7 01:21:57.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Jun  7 01:21:57.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
*Jun  7 01:21:57.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/0, changed state to down
*Jun  7 01:21:57.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/1, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel3, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel11, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel13, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel20, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel30, changed state to down
*Jun  7 01:21:57.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel40, changed state to down
*Jun  7 01:21:58.199: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Jun  7 01:21:58.451: %SYS-5-CONFIG_I: Configured from memory by console
*Jun  7 01:21:59.359: %SYS-5-RESTART: System restarted --
*Jun  7 01:21:59.399: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL GBIC Slot 0/1 GBIC is missing
*Jun  7 01:21:59.399: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL GBIC Slot 0/2 GBIC is missing
*Jun  7 01:21:59.399: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL GBIC Slot 0/3 GBIC is missing
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/1:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/2:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/3:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/4:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/7:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/8:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/9:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/10:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/11:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/12:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/14:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/15:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/16:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/17:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/18:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/19:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/20:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/21:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/23:0, changed state to down
al1/0/24:0, changed state to downOWN: Interface Seri
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/25:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/26:0, changed state to down
*Jun  7 01:21:59.619: %LINK-3-UPDOWN: Interface Serial1/0/27:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial1/0/28:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/1:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/2:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/4:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/5:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/6:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/7:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/8:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/9:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/10:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/11:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/12:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/13:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/14:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/15:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/16:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/17:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/18:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/19:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/20:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/22:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/24:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/25:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/26:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/27:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial2/0/28:0, changed state to down
*Jun  7 01:21:59.623: %LINK-3-UPDOWN: Interface Serial3/3:0, changed state to down
*Jun  7 01:21:59.631: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun  7 01:21:59.631: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun  7 01:21:59.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jun  7 01:21:59.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Jun  7 01:21:59.695: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T31/0 Physical Port Link Down
*Jun  7 01:21:59.695: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T32/0 Physical Port Link Down
*Jun  7 01:21:59.695: %ENTITY_ALARM-6-INFO: ASSERT INFO Fa4/0 Physical Port Administrative State Down
*Jun  7 01:21:59.695: %ENTITY_ALARM-6-INFO: ASSERT INFO Fa4/1 Physical Port Administrative State Down
*Jun  7 01:21:59.695: %SNMP-5-COLDSTART: SNMP agent on host Core_7206_1 is undergoing a cold start
*Jun  7 01:22:00.239: %SYS-6-BOOTTIME: Time taken to reboot after reload =  318 seconds
*Jun  7 01:22:00.783: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Jun  7 01:22:00.783: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
*Jun  7 01:22:06.667: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T31/0 Transmitter is sending remote alarm
*Jun  7 01:22:06.667: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T31/0 Receiver has loss of signal
*Jun  7 01:22:07.915: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T32/0 Transmitter is sending remote alarm
*Jun  7 01:22:07.915: %ENTITY_ALARM-6-INFO: ASSERT MAJOR T32/0 Receiver has loss of signal
        Core_7206_1>
Core_7206_1>
KouiQtech
Community Member
if the trouble is not fixed yet, did you do this to know where is location in register
#show version (to know the register address
#show region ( to locate the part)
hope that will help
Preston Chilcote
Those must be coming from the boot image, which doesn't have all the feature support as the regular IOS image.  The messages are just warnings when configuring some of the features that the boot images doesn't understand.
