7206 Npe G2 high cpu problems
Umit AYDINLI
I have a lot of cisco 7206 vxr deviceses. I have a high cpu problem.
I have a 7206 vxr g2. I used to use ebgp for three upstream carrier. I used to bgp full route table method. I have about 800 Mbps active traffics and behing the router about 1600 active customers.
Could you advice me how can I trouble shoot this high cpu problem?
#sh int gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 000c.cf1d.d01b (bia 000c.cf1d.d01b)
  Description: ***** GW Interface *****
  Internet address is 213.144.96.1/24
  MTU 1700 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 31/255, rxload 45/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, media type is RJ45
  output flow-control is XON, input flow-control is unsupported
  ARP type: ARPA, ARP Timeout 03:20:00
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 4w4d
  Input queue: 0/4096/4860/1347216 (size/max/drops/flushes); Total output drops: 13800835
  Queueing strategy: fifo
  Output queue: 0/4096 (size/max)
  30 second input rate 177466000 bits/sec, 35236 packets/sec
  30 second output rate 125457000 bits/sec, 33418 packets/sec
     2016938526 packets input, 1849362236 bytes, 4794 no buffer
     Received 50788313 broadcasts (15690571 IP multicasts)
     51133 input errors, 44 CRC, 0 frame, 0 overrun, 51089 ignored
     0 watchdog, 27438132 multicast, 0 pause input
     1827169002 packets output, 1537189058 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
#sh int gigabitEthernet 0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 000c.cf1d.d01a (bia 000c.cf1d.d01a)
  Description: ***** Internet Access Port *****
     reliability 255/255, txload 95/255, rxload 84/255
  Input queue: 0/4096/15826/2230509 (size/max/drops/flushes); Total output drops: 17298
  30 second input rate 332999000 bits/sec, 63563 packets/sec
  30 second output rate 373472000 bits/sec, 71761 packets/sec
     1133386686 packets input, 849294076 bytes, 17917 no buffer
     Received 37718109 broadcasts (0 IP multicasts)
     421 input errors, 0 CRC, 0 frame, 0 overrun, 421 ignored
     0 watchdog, 2554 multicast, 0 pause input
     2675409271 packets output, 2343996450 bytes, 0 underruns
     4 output errors, 0 collisions, 4 interface resets
     4 lost carrier, 0 no carrier, 0 pause output
#sh int gigabitEthernet 0/3
GigabitEthernet0/3 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 000c.cf1d.d019 (bia 000c.cf1d.d019)
  Description: ***** Metro Ethernet *****
     reliability 255/255, txload 64/255, rxload 59/255
  Input queue: 0/4096/99466/2578258 (size/max/drops/flushes); Total output drops: 45184295
  30 second input rate 234300000 bits/sec, 51018 packets/sec
  30 second output rate 251936000 bits/sec, 44635 packets/sec
     1015412816 packets input, 1352601046 bytes, 41095 no buffer
     Received 157083858 broadcasts (0 IP multicasts)
     296819 input errors, 413 CRC, 0 frame, 0 overrun, 296406 ignored
     0 watchdog, 157681185 multicast, 0 pause input
     2426528064 packets output, 508387291 bytes, 0 underruns
#sh ver
Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.2(33)SRD2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 20-May-09 21:32 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
7206_VXR_G2 uptime is 26 weeks, 5 days, 19 hours, 17 minutes
System restarted at 15:58:49 GMT+2 Tue Aug 30 2011
System image file is "disk2:/c7200p-spservicesk9-mz.122-33.SRD2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 29813402
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 90 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
3 Serial interfaces
8 Channelized E1/PRI ports
1 Channelized E3 port
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
#sh processes cpu sorted
CPU utilization for five seconds: 75%/62%; one minute: 71%; five minutes: 69%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
246   371404700   1324881     280347  7.91%  2.23%  1.71%   0 BGP Scanner
249    834493961271325781         65  0.79%  0.94%  0.96%   0 EIGRP-IPv4: PDM
  85   1989393561828373765        108  0.79%  0.84%  0.80%   0 IP Input
245    35318844 989199499         35  0.47%  0.59%  0.54%   0 EIGRP-IPv4: PDM
125    85488388 108901503        785  0.47%  0.55%  0.56%   0 IP RIB Update
133    90593692  95054980        953  0.47%  0.56%  0.56%   0 static
241    30375216 679746761         44  0.31%  0.32%  0.32%   0 EIGRP-IPv4: PDM
153   254854208 212933212       1196  0.31%  0.61%  0.68%   0 BGP Router
  24    42637432 339131952        125  0.23%  0.20%  0.22%   0 ARP Input
239    30037548 233726388        128  0.23%  0.11%  0.11%   0 EIGRP-IPv4: PDM
   3         164       625        262  0.15%  0.04%  0.00%   2 SSH Process
214     9704812  36008323        269  0.15%  0.07%  0.07%   0 SNMP ENGINE
  48     2342552    292826       7999  0.15%  0.01%  0.00%   0 Per-minute Jobs
  12       19224  16121638          1  0.07%  0.00%  0.00%   0 IPC Periodic Tim
128      5841603820724583          0  0.07%  0.08%  0.07%   0 HQF Shaper Backg
261    12606892 460359880         27  0.07%  0.07%  0.07%   0 EIGRP-IPv4: HELL
221      410440 488309363          0  0.07%  0.04%  0.05%   0 PPP manager
236     10576081928546169          0  0.07%  0.09%  0.07%   0 IP SLAs Event Pr
129      4362563820729036          0  0.07%  0.07%  0.07%   0 HQF Input Shaper
250     7143556 346717390         20  0.07%  0.05%  0.06%   0 EIGRP-IPv4: HELL
117     1054272  22516667         46  0.07%  0.06%  0.07%   0 CEF: IPv4 proces
247      838676  42421526         19  0.07%  0.00%  0.00%   0 EIGRP-IPv4: HELL
101     1316444  65438354         20  0.07%  0.00%  0.00%   0 Spanning Tree
  89    14028036 117415925        119  0.07%  0.06%  0.07%   0 ADJ resolve proc
222      357576 488309506          0  0.07%  0.02%  0.02%   0 PPP Events
212     6874068  69959410         98  0.07%  0.05%  0.06%   0 IP SNMP
  26           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  27           0         1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  25      285844  16814593         16  0.00%  0.00%  0.00%   0 ARP Background
  30           0         4          0  0.00%  0.00%  0.00%   0 Entity MIB API
  28           0         5          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  29           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  33         116     16995          6  0.00%  0.00%  0.00%   0 Serial Backgroun
  31        5372    160564         33  0.00%  0.00%  0.00%   0 EEM ED Syslog
  35           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  36           0        19          0  0.00%  0.00%  0.00%   0 DDR Timers
  37           0         2          0  0.00%  0.00%  0.00%   0 SMART
  32         784         5     156800  0.00%  0.00%  0.00%   0 PrstVbl
  39       17824  16121633          1  0.00%  0.00%  0.00%   0 GraphIt
  40           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  15           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  42           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  43     2817912   4977553        566  0.00%  0.03%  0.01%   0 Net Background
  23        3352   3232113          1  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  22           0         1          0  0.00%  0.00%  0.00%   0 Exception contro
  34           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  38           0         1          0  0.00%  0.00%  0.00%   0 RFS server proce
  14       12304  16121640          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  49          20        84        238  0.00%  0.00%  0.00%   0 IF-MGR control p
  50          20       393         50  0.00%  0.00%  0.00%   0 IF-MGR event pro
  51           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  52           0         2          0  0.00%  0.00%  0.00%   0 INTR MGR PROCESS
  53        9712   5276901          1  0.00%  0.00%  0.00%   0 Transport Port A
  54       51772   4807188         10  0.00%  0.00%  0.00%   0 HC Counter Timer
  41           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  56           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
  57           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  58           0         2          0  0.00%  0.00%  0.00%   0 Hawkeye Backgrou
  59           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  60           0         2          0  0.00%  0.00%  0.00%   0 FPD Management P
  44           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  62      159304    919190        173  0.00%  0.00%  0.00%   0 Collection proce
  63           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  64           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  65           8         6       1333  0.00%  0.00%  0.00%   0 Flash Card Oir
  66           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  45        4968    342666         14  0.00%  0.00%  0.00%   0 Logger
  68           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
  46       27764  16121595          1  0.00%  0.00%  0.00%   0 TTY Background
  70           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
#sh processes memory sorted
Processor Pool Total:  850287212 Used:  508707208 Free:  341580004
      I/O Pool Total:   67108864 Used:    6691312 Free:   60417552
Transient Pool Total:   16777216 Used:     122356 Free:   16654860
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
153   0 2167646800 3258059216  369532500      52448          0 BGP Router
125   0 2566262772  823460356   78550656          0          0 IP RIB Update
   0   0   51236456    7371184   39439020          0          0 *Init*
   0   0 3116389520 2968229116    7423404    3661344      17420 *Dead*
   5   0  358534536  332228156    4457884  133743676  135805988 Pool Manager
239   0 2924544240 2945053956    4331500      19108     719136 EIGRP-IPv4: PDM
   0   0          0          0    2033364          0          0 *MallocLite*
249   0 1396961512 1353257724    1081536     146924    1013924 EIGRP-IPv4: PDM
  96   0     796772      47276     710012          0          0 PPP SIP
  84   0     535788      25248     526860          0          0 IP ARP Adjacency
207   0     446176          0     507300          0          0 CCPROXY_CT
105   0     580832      88200     500112          0          0 SSS Manager
222   0     499536      13776     494768        780          0 PPP Events
124   0     449952     107988     342492          0          0 IP Background
100   0     311152        188     324088          0          0 SSM connection m
133   0     820972     615892     323388          0          0 static
  31   0     279992          0     289504     113400          0 EEM ED Syslog
  89   0 1027472104 1153134984     265224    6600880   30557704 ADJ resolve proc
241   0 3208006648 3210118876     224048      48436     392504 EIGRP-IPv4: PDM
  62   0    3442292    1015964     210036          0          0 Collection proce
   1   0   37852324   37808240     182816          0          0 Chunk Manager
188   0     142428       9180     148940          0          0 EEM Server
  85   0  731131288  534554412     119264   44456588   10697448 IP Input
164   0      65848          0      90972          0          0 QOS_MODULE_MAIN
117   0      90752         76      90752          0          0 CEF: IPv4 proces
  43   0     436500        248      83176      65260          0 Net Background
256   0     285140      11248      82884          0          0 Tag Control
115   0      65752          0      78876          0          0 CEF background p
167   0     111976       3912      67600          0          0 Crypto ACL
  82   0      49404          0      62528          0          0 IPAM Manager
  24   0 3298366036 3366734816      62384          0   13954704 ARP Input
Message was edited by: Umit AYDINLI because i added sh tech output.
2 Accepted Solutions
Edison Ortiz
Your interfaces are reporting a high number of input and output drops for the 4week period.
Can you make sure the duplex/speed are matching at either end and also verify cabling?
Packet drops in the router can create high CPU conditions.
What other services you have enabled in the router?
Can you post your sanitize config?
Edison
Vishnu Asok
Hi Umit
With the information you provided, we cannot arrive at a conclusion. The CPU utilisation will depend on several factors like-
1)features configured
2)Switching path taken by packets
3)Broadcasts and multicast packets received
4)Packets direct to the router
From the outputs, I see that you have 62 % interrupts and remaining CPU is accounted by various process which is pretty normal.
I notice that you have significant traffic flowing through the router. I would say you are hitting the hardware limitation with the current flow of traffic.
As per documents NPE-G2 can handle up to 1024 Mbps traffic, but never expect more than 800 Mbps with heavy configuration.
As you add ACL's, encryption, QOS, etc - performance will decline significantly from the given numbers, unless it is a hardware-assisted platform, such as the ASR 1000, 7600 or 12000
You can compare the router performance in below link-
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
The only logical thing we can do now is to perform a CPU profiling and identify the functions that are interrupting the CPU. Once the function is identified, we can try tweaking/ optimizing  the associated configuration . However in your case I doubt there is anything more we can do to reduce CPU other than redirecting some traffic.
Vishnu
Edison Ortiz
Edison
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From what you've posted, you might just be occasionally offering too much load to this router.  A G2 can struggle with two gig links.
Disclaimer
Posting
BTW, reason for this statement, gig Ethernet can require up to 1.488 Mpps.  So two gig links could require up to about 3 Mpps, and your three gig links could require up to about 4.5 Mpps.  Since a -G2 is rated at 2 Mpps, see the reason why it can struggle?
Even the "fastest" 7200 "engine", the discontinued NSE-1, rated at 3.5 Mpps (PXF), might struggle with your three gig links.  A 5 Mpps ASR would probably be the most suitable choice for your current usage.
Looking at your stats, there is some "low hanging fruit", i.e. some configuration options that might help.  These include: insuring your BGP peering is using MTU, not just 576; insuring buffer usage is just "hits"; enabling compiled ACLs (if supported and assuming you're using more than a few ACLs); tuning SPD; and perhaps reducing your TCP window size to only accept 2 to 4 packets (to throttle BGP updates).
Vishnu Asok
Hi Umit
Vishnu
