02-20-2007 06:09 PM - edited 03-03-2019 03:50 PM
I put the output of
more crashinfo file
into output interpreter on CCO and it couldn't give me any sugesstions. I searched through Bug Toolkit and found no matching footprints.
Any suggestions after looking at the attached files.
02-20-2007 07:33 PM
Since you have CCO account, you have to use the Output Interpreter https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl not the Bug Toolkit.
Paste the "Show version" output and the "-Traceback= 60503934 60105AD8 60109CF4"
Edit: Oops you already did that :)
02-20-2007 07:33 PM
Have I hit S/W defect CSCdz57007 ?
02-20-2007 07:38 PM
I can't find anything in the crashinfo that triggers it except the line "Cause 0000401C (Code 0x7): Data Bus Error exception"
Did you by chance, did something before it crash like plugging new module?
02-20-2007 07:55 PM
I got my customer to tftp teh crashinfo file and send me that file rather than the output of the command
more crashinfo.
Then I used teh output interpreter on the tftp'ed crashinfo file and it pointed me to S/W defect CSCdz57007. But customer is running 12.2(31) which should not see this issue as per CSCdz57007.
02-20-2007 07:44 PM
Its hard to say, there is something about bugs notification from vendors that I rather not discuss here. It never hurts to upgrade to latest IOS even your current is GD. Whenever I have a problem and using old IOS, the first word I hear from my vendor is to upgrade to latest IOS and get back to them if I still have problem :)
