7206vxr Compatibility
Snydersh1_2
Level 2
Level 2
Does anyone know of the link that shows all the interface cards that can be used w/ the 7206vxr?
Snydersh1_2
Level 2
Level 2
Will the PA-T3+ support partial DS3's?
You need the PA-MC-T3 for this.
ajagadee
Shannon,
The below link should list the cards that are supported on the 7200VXR Routers.
http://www.cisco.com/univercd/cc/td/doc/product/core/7206/port_adp/config/3875in.htm#wp1053970
The Cisco 7200 series routers have a finite data-carrying capacity, referred to as bandwidth, that affects the port adapter distribution in the chassis, as well as the number and types of port adapters you can install.
Additional information on PA-T3+
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_rout/cfig_nts/6093st3p/6093prep.htm#xtocid234052
Let me know if it helps.
Arul
