7206VXR: Creating a vlan
sudip.acharya1
I am trying to create a vlan on the 7206 but I get a "%invalid input detected" error.
I am using the command Router# vlan VLAN-ID.
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(14)E6
Thanks.
5 Replies 5
paolo bevilacqua
You never create vlans on true routers.
You connects to switches that have already the vlans using subinterfaces.
Also, you are reporting an incomplete IOS version string.
Here is the complete string. We are trying to see if we can have a vlan here due to the way the switch provided by our carrier is setup.
I am able to run "sho Vlans" (0 vlans are confgured).
IOS (tm) 7200 Software (C7200-IS-M), Version 12.1(14)E7, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 08-Oct-03 21:57 by hqluong
Image text-base: 0x60008C08, data-base: 0x612B2000
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(14)E6, EARLY DEPLOYMENT REL
EASE SOFTWARE (fc1)
PhlRT06 uptime is 6 hours, 46 minutes
System returned to ROM by reload at 09:07:32 est Tue Sep 22 2009
System restarted at 09:08:25 est Tue Sep 22 2009
System image file is "disk0:c7200-is-mz.121-14.E7.bin"
cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 30826772
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
4 FastEthernet/IEEE 802.3 interface(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
47040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
As mentioned above, router never "creates" VLANs.
Try to explain what problem are you trying to solve exactly.
Hello Sudip,
as Paolo has explained this is a router and not a multilayer switch.
if your provider sends to you 802.1Q tagged frames with vlan X you just need
int f0/0
no ip address
int f0/0.10
enc dot1q X
! other commands here
X stands for a vlan-id number
Hope to help
Giuseppe
a.nenni
I sent you a private message...
