7206VXR NPE-400 Points
yaplej
I currently have a 7206VXR with an NPE-400 installed.  I want to install a SA-VAM2+ so I can configure GETVPN.
Its currently configured as follows
Bus1:
PA-T3+
I/O-2FE/E
Bus2:
PA-GE
I would like to add the SA-VAM2+ to Bus2.  This would oversubscribe Bus2 by 400 points because the SA-VAM2+ card is 600 points.  Our router never sees more than around 90Mbps traffic or 45Mbps full-duplex currently.  So the SA-VAM2+ will never use 100% of its avaliable bandwidth even if we encrypted 100% of our traffic to/from the PA-T3+ with GETVPN.  In addition the PA-GE interface is used to redirect traffic to a WCCPv2 cache so it only sees that same 90Mbps (45Mbps in+45Mbps out) to/from the PA-T3+.  The I/O-2FE/E has both interfaces in use but only for redundancy and combined they only see a max of 90Mbps or 45Mbps full-duplex.
This is really just an intermediate solution until I can get an NPE-G1/NPE-G2.  Then I plan on moving the SA-VAM2+ card into the IO slot using a Port Adapter Jacket Card (C7200-JC-PA).  Then the points will not be a problem.
The question is other than the warning message would this load cause any issues?
Thanks.
Giuseppe Larosa
Hello Yaplei,
verify that  SA-VAM2+  is supported by NPE-400, othe then this you should be fine
see
http://www.cisco.com/en/US/docs/routers/7200/configuration/7200_port_adapter_config_guidelines/3875In.html#wp1085607
and
Hardware Requirements
Specific hardware prerequisites that ensure proper operation of the SA-VAM2+ follow:
The SA-VAM2+ is compatible with the NPE-225, NPE-400, NPE-G1 or NPE-G2 processor on the Cisco 7200VXR routers.
For  routers using SA-VAM2+, we recommend a minimum configuration of 256 MB  of memory; for more efficient performance, we recommend 512 MB of  memory.
The  SA-VAM2+ utilizes a specific number of bandwidth points in functioning,  which affect performance. For more information on bandwidth  requirements, see the http://www.cisco.com/univercd/cc/td/doc/product/core/7206/port_adp/config/3471in.htm#xtocid20Cisco 7200 Series Port Adapter Hardware Configuration Guidelines
http://www.cisco.com/en/US/docs/ios/12_3/feature/guide/ft_vam2p.html#wp1077571
Hope to help
Giuseppe
Giuseppe Larosa
Hello Yaplei,
see
and
Hope to help
Giuseppe
The SA-VAM2+ is supported by the NPE-400 and our NPE-400 has 512MB of ram.  The issue is that we
are using all the ports on our c7200-I/O-2FE/E and the PA-GE.  So the points will be oversubscribed.  Its just the total throughput will be quite low.  I expect it will work but wanted to get some input from someone who has more experiance with the 7200.
Thanks.
