7206VXR PPPOE IP Pools
Island3r
Hi Guys
I'm setting up a BRAS router for different PPPOE services. They are separated by VLANS and we would like each service/VLAN to receive a different IP Address range on the customer modem, here's the info:
They are all incoming on one interface
VLAN 200 - Pool1 10.0.0.1 - 10.0.0.200 (dynamically assigned)
VLAN 300 - Pool2 20.0.0.1 - 20.0.0.200 (dynamically assigned)
VLAN 400 - Pool3 30.0.0.1 - 30.0.0.200 (statically assigned)
I'm not sure how to config this, I know I'll probably have to use virtual-templates, bba-groups, IP Local Pools but not sure how to put all this together and where to assign the interface IP Address and Gateway IP Address.
Hope you guys can help!
something like the below might work:
interface Vlan 200
ip address 10.0.0.1 255.255.255.0
interface Virtual-Template 200
ip unnumbered Vlan200
no ip directed-broadcast
peer default ip address pool VLAN200
ppp authentication pap
ip local pool VLAN200 10.0.0.2 10.0.0.200
Hi, thanks for the reply, that looks similar to what I've been researching. I would then do the same for the other VLANs?
I was also reading that maybe I would need to make sub interfaces interface gig0/2.200, gig0/2.300 etc. Would that be necessary?
