Configure IRB/BVI on CSR1000v
CiscoBrownBelt
Level 6
Level 6
So certain commands such as choosing IEEE protocol are not an option. Neither is configuring a VLAN in the VLAN database or adding the "bridge group" to a interface. Not sure if it is this VIRL CSR1000v or what but I can't find documentation for how to configure this on a CSR1000v. Any help?
2 Accepted Solutions
I think the CSR1000v has VxLAN support only; bridge groups are obsolete, and you need to use bridge domains instead...
Hello
CSR1000v is a router not a switch so no switch virtual interfaces (SVI) and IRB/BVI is now replaced with Bridge Domain Interfaces.(BDI), however ive not checked if this Virl vm supports it.
Kind Regards
Paul
Hello
Kind Regards
Paul
