7206Vxr Router Issue Urgent !
m.pandey
One by One the module in this Cisco Router is going bad. No idea how to proceed and check what was the reason for this. If I am giving command
#show context
it gives following :-
System was restarted by error - an Error Interrupt, PC 0x60802B30 at 15:55:38 GM
T Tue Jul 26 2005
7200 Software (C7200-IS-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Compiled Tue 24-May-05 19:38
Image text-base: 0x60008AF4, data-base: 0x61CB6000
Stack trace from system failure:
FP: 0x80007D30, RA: 0x60802B30
FP: 0x80007ED8, RA: 0x608058B8
FP: 0x80007F10, RA: 0x60008BA8
FP: 0x80007F30, RA: 0x80008A8C
FP: 0x80007F50, RA: 0x8000867C
FP: 0x80007FC0, RA: 0xBFC045A4
FP: 0x80008010, RA: 0x60802A40
Fault History Buffer:
Signal = 0, Code = 0x0, Uptime 6d17h
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 64AD5128, s8 : 00000000, ra : 00000000
EPC : 00000000, SREG : 00000000, Cause : 00000000
Error EPC : 00000000, BadVaddr : 00000000
Everyday some or the other issue is happening with the interfaces available in this router but I don't have the clue how to go ahead towards working on real issue resulting on all this.
mlund
Level 7
Level 7
Hi.
I used your output in the "output interpreter" and this is what it says.
ERROR: An 'Error Interrupt' crash signifies that a component other than the processor
has detected a fatal error. This most likely indicates a hardware issue.
TRY THIS: Paste the "show tech-support" and "show stacks" command output into
the Output Interpreter to display the potential issues and fixes. If a new module
has been recently installed, first try to remove it to verify whether it is responsible
for the error interrupt. If the error interrupt persists, try to re-seat all removable
components. If the problem is not resolved, consider opening a service request
with Cisco at TAC Service Request Tool.
REFERENCE: For more information, see: Troubleshooting Hardware and Booting Problems.
Troubleshooting Router Crashes
Less Common Types of System Crashes
Hope this helps.
/Mike
chfloyd
Hard to tell for sure in this case, but it looks like you may have a defective Network Processing Engine (npe). My suggestion would be to open a TAC case for further analysis. This could be a defective processor or a problem with any number of ASIC's onboard the NPE.
--Brent
