7206VXR Throughput problems.
markraves
Hello
I seem to have a bit of a problem with my 7206VXR Router.
I have a few customers (about 30 or so) behind the router on wifi, adsl and fibre.
Now when I do a speed check against a reliable speedometer, or I download a file from my own computer (which is not behind this router, and on a 50Mbit line) I get between 1Mbit and 1.5Mbit, both upstream / downstream.
I have a spare 7206VXR (old boxes, you never know..) and I get exactly the same rates with identical config.
I've yelled at my isp, rattled the warhammer. But they insist there's more speed available.
So, tonight I took my laptop, removed the router, and did a speed test.
30mbit downstream / 20Mbit upstream, with no router present.
Damn.
So, I removed my routerconfig, and tuned it with a simple, down-to-earth config, and connected ONLY my laptop.
Intrestingly enough, this allowed an upstream of 20Mbit, but back to 1-1.5Mbit downstream.
So I removed ALL the NAT config, and placed my laptop on a public IP, further minimizing the config, but this resulted in the same terrible downstream speed. (still got 20Mbit upstream though.)
I've got no idea whatsoever what's causing this problem.
Under no circumstance does the router show any load:
CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0%
These numbers are maybe up to 2,3 percent when all the customers are attached.
I also have a spare I/O card, the midplane with the PCMCIA card, and console port. I've tried to change that as well, and another I/O card (the fa3/0) changed that as well, all with the same results. (none).
So what I'm thinking, either the software dosen't support the NPE-300 network prosessor engine, or I'm a f#?%up with
IOS commands. On one of the routers I get BAD CPU_ID during boot, but only one of them.
I've posted a simple config, and the output of SH VER as well.
Does anybody see some simple stupid mistake / error here?
Thanks for your time;=)
Router#sh run
Building configuration...
Current configuration : 1007 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip domain lookup
ip dhcp pool test1
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
domain-name h00rer.com
ip cef
interface FastEthernet0/0
ip address 80.xx.123.2 255.255.255.252
ip nat outside
duplex full
interface FastEthernet3/0
no ip address
duplex full
interface FastEthernet3/0.192
encapsulation dot1Q 192
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip nat pool ADSL-NAT-POOL 80.xx.123.2 80.xx.123.2 netmask 255.255.255.252
ip nat inside source list 8 pool ADSL-NAT-POOL overload
ip classless
ip route 0.0.0.0 0.0.0.0 80.xx.123.1 name Default_Gw
no ip http server
access-list 8 permit 10.0.0.0 0.0.0.255
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
line vty 0 4
end
Due to 4000 letter limitations, I will post output of SH VER in a reply to this thread.
5 Replies 5
markraves
This is router1's SH VER:
Router#sh ver
IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(6a), RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 02-Apr-04 15:51 by kellythw
Image text-base: 0x60008AF4, data-base: 0x61FF2000
ROM: System Bootstrap, Version 12.2(1r) [dchih 1r], RELEASE SOFTWARE (fc1)
Router uptime is 31 minutes
System returned to ROM by reload at 00:08:35 CEST Tue Jul 31 2007
System image file is "disk0:c7200-js-mz.123-6a.bin"
Last reload reason: Reload command
cisco 7206VXR (NPE300) processor (revision D) with 229376K/65536K bytes of memor
y.
Processor board ID 25859418
R7000 CPU at 262MHz, Implementation 39, Rev 2.1, 256KB L2 Cache
6 slot VXR midplane, Version 2.5
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
PCI bus mb0_mb1 has 400 bandwidth points
PCI bus mb2 has 0 bandwidth points
2 FastEthernet/IEEE 802.3 interface(s)
125K bytes of non-volatile configuration memory.
125440K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Router#
This is router 2's SH VER:
Router#sh ver
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT S
OFTWARE
Router uptime is 3 minutes
cisco 7206VXR (NPE300) processor (revision B) with 229376K/65536K bytes of memor
y.
Processor board ID 21274384
R7000 CPU at 262MHz, Implementation 39, Rev 1.0, 256KB L2 Cache
6 slot VXR midplane, Version 2.0
Bridging software.
Configuration register is 0x100 (will be 0x0 at next reload)
Router#
Sorry for all the pasting here, but I thought I'd post the SH DIAG as well here, to let you in on my expansion slots...
Router#sh diag
Slot 0:
Fast-ethernet on C7200 I/O card with MII or RJ45 Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 00:57:00 ago
EEPROM contents at hardware discovery:
Hardware revision 2.1 Board revision B0
Serial number 16704758 Part number 73-4092-03
FRU Part Number: C7200-IO-FE-MII/RJ45=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 83 02 01 00 FE E4 F6 49 0F FC 03 00 00 00 00
0x10: 58 00 00 00 00 05 24 00 00 00 FF FF FF FF FF FF
Slot 3:
Fast-ethernet (TX-ISL) Port adapter, 1 port
Hardware revision 1.4 Board revision B0
Serial number 21920029 Part number 73-1688-05
FRU Part Number: PA-FE-TX
0x00: 01 11 01 04 01 4E 79 1D 49 06 98 05 00 00 00 00
0x10: 58 00 00 00 00 09 02 00 FF FF FF FF FF FF FF FF
I can suggest Only one thing to you....
At the time of working Environment mean when problem persist at that time, Please capture some traffic by using sniffer. and analyze.
That is only can help to resolve Throughput problem.
Dharmesh Purohit
No eveident mistakes. Do you have acess to downloads ? Can you upgrade to latest 12.3 ? (line (40) or so.
No, I don't have access to downloads.
This is indeed very strange. Later yesterday night, I took the spare FA card and inserted it in slot 2/0.
Then I connected the wan interface in slot 2/0 instead of 0/0.
When I had a speed test (with my full configuration) I got 1/20Mbit from nat'ed net, and I got 4/5Mbit from a net without nat. I did this about five times, and no variations to speak about.
I'm utterly clueless.
Purohit: Well, the problem kinda persists ALL the time, so it shouldn't be hard finding the time. I will try some sniffing.
Thanks;=)
