7301 Router %Error in authentication
burleyman
Level 8
Level 8
When I try and go into enable mode I enter the password and I get %Error in authentication. Any thoughts? I was in the router eailier and used the same password as I am now and it worked no problem.
Mike
John Blakley
You may have to reset it. What was the last thing you did it it, and are you consoled or terminaled into it?
John
HTH, John *** Please rate all useful posts ***
Oh, and I meant reset the password on the router if you can't get into it.
I tried both telnet and console both with the same results. The last thing I did was to show int and show run....I did not change or save anything.
Mike
That's weird. You may have to reset the password through a console connection.
Here's a link:
http://www.cisco.com/en/US/docs/routers/7300/install_and_upgrade/7301/7301_install_and_config_guide/5418c.html#wp1128746
--John
