7500 Series Password Recovery
aseijas
Hi everybody,
We have a 7507 Router in WAN (hub and spoke) with 75 branch and we missed the enable secret password. we´ll do password recovery procedure and we have some doubts about the procedure. As it´s show below ....
"... Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-JSV-M), Version 12.2(23), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 28-Jan-04 14:00 by kellmill
Image text-base: 0x60010948, data-base: 0x6194C000
ROM: System Bootstrap, Version 12.0(10r)S1, RELEASE SOFTWARE (fc1)
7500central uptime is 1 year, 3 weeks, 5 hours, 14 minutes
System returned to ROM by reload at 06:57:24 UTC Sun Nov 9 2003
System restarted at 06:28:04 UTC Sun Mar 21 2004
System image file is "slot0:rsp-jsv-mz.122-23.bin"
cisco RSP4+ (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
1 CIP2 controller (2 IBM Channels).
1 VIP2 controller (1 FastEthernet)(8 Ethernet).
1 VIP2 R5K controller (4 Serial).
8 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
2 IBM channel interface(s)
123K bytes of non-volatile configuration memory.
32768K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
20480K bytes of Flash PCMCIA card at slot 1 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 3 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.2(23), RELEASE SOFTWARE (fc2)
Compiled Wed 28-Jan-04 14:06 by kellmill
Slave: Loaded from system
Slave: cisco RSP4+ (R5000) processor with 131072K bytes of memory.
Configuration register is 0x102 ...."
this router have many hardware over the basis. The doubts is if the password recovery procedure run doesn´t matter all the hardware involve it. what others cautions we have to follow in order to do the recovery the most softly.
Thank a lot for your help,
AS.
thisisshanky
Level 11
Level 11
The password recovery procedure explained in this link is applicable to 7500 series routers. Check this out!
http://www.cisco.com/en/US/products/hw/routers/ps359/products_password_recovery09186a00800942d2.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
pushkar1782
yes....u need to change your config. register value from ( 0x2102 ) to 0x2142 and then change the password.........and then again change this value to 0x2102 .
the routers console speed should be 9600 bps ( which is by default ) .....to change these values....
see what the results are ...
