10-23-2012 12:48 AM - edited 03-04-2019 05:56 PM
Dear Experts,
would you please clarify this log message:
*Oct 23 06:20:07 UTC: %FPD_MGMT-3-INCOMP_IMG_VER: Incompatible ROMMON (FPD ID=5) image version detected for 7600-SIP-200 card in slot Detected version = 1.3, minimum required version = 1.4. Current HW version = 2.303.
H/W Field Programmable Current Min. Required
Slot Card Type Ver. Device: "ID-Name" Version Version
1 7600-SIP-200 2.303 1-I/O FPGA 1.3 1.3
2-EOS FPGA 1.220 1.220
3-PEGASUS TX FPGA 1.133 1.133
4-PEGASUS RX FPGA 1.6 1.6
5-ROMMON 1.4 1.4
1/0 SPA-2XOC3-POS 1.0 1-I/O FPGA 3.4 3.4
1/1 SPA-8XCHT1/E1 1.5 1-ROMMON 2.12 2.12
2-I/O FPGA 2.8 2.8
just today i did IOS upgrade ( 12.2(33) SRD 8 ) and i got above log.
Please advice.
Ahmed
10-24-2012 10:43 AM
This message typically means that you need to upgrade FPD software on the SIP module. Guidelines here:
The easiest way is to just place fpd package file on flash disk before upgrading. Since you already did, you can place the file and reload router again with SRD8.
File you can find here (double check if the supervisor selection is correct):
I see, though, that current version should be 1.3 while the output you posted shows 1.4 already. Did you do the upgrade since seeing the message?
5-ROMMON 1.4 1.4
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
