7600 module restart
ibrahim_hassan
Dear All,
    i have 7600 , module 1 is restarted and crash file created.
Giuseppe Larosa
Hello Ibrahim,
from attached crashinfo:
SLOT 1: 00:00:05: %SYS-5-RESTART: System restarted --
Cisco IOS Software, cwlc Software (sip1-DW-M), Version 12.2(33)SRA7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 05-Mar-08 17:57 by prod_rel_team
SLOT 1: 00:00:05: %SCP-5-ONLINE: Module online
SLOT 1: Aug 21 01:47:27 EGT: %SIPSPA-6-OIR: Bay 0 SPA Power changed to On
SLOT 1: Aug 21 01:47:27 EGT: %SIPSPA-6-OIR: Bay 1 SPA Power changed to On
SLOT 1: Aug 21 01:47:28 EGT: %SIPSPA-6-OIR: Bay 0 SPA OK changed to On
SLOT 1: Aug 21 01:47:28 EGT: %SIPSPA-6-OIR: Bay 1 SPA OK changed to On
SLOT 1: Aug 21 01:47:36 EGT: %SPA_PLUGIN-6-FIRMWARE_DOWNLOADING: SPA-8XCHT1/E1[1/0]: Downloading SPA firmware (bundled)...
SLOT 1: Aug 21 01:47:37 EGT: %SPA_PLUGIN-6-FIRMWARE_DOWNLOADING: SPA-8XCHT1/E1[1/1]: Downloading SPA firmware (bundled)...
SLOT 1: Aug 21 01:47:40 EGT: %SPA_PLUGIN-6-FIRMWARE_APPS_DOWNLOADING: SPA-8XCHT1/E1[1/0]: Downloading SPA firmware application (bundled)...
SLOT 1: Aug 21 01:47:40 EGT: %SPA_PLUGIN-6-FIRMWARE_APPS_DOWNLOADING: SPA-8XCHT1/E1[1/1]: Downloading SPA firmware application (bundled)...
%ALIGN-1-FATAL: Illegal access to a low address 23:06:46 EGT Sun Oct 4 2009
addr=0x144, pc=0x4088C7C4, ra=0x4088C618, sp=0x43A65968
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
The SIP linecard in slot1 had a SW crash on the 8xE1 SPA
I will look at third attachment to find out your IOS image.
Edit:
so you have 12.2(33)SRA7 and the SIP is a SIP200.
looking at release notes for your image is the next step
Edit2:
there are some bugs about Sip200 or SPA 8 E1
example:
CSCsj34043
this is similar but applies to OC-3 SPA + sip200
Hope to help
Giuseppe
