03-23-2006 02:15 AM - edited 03-03-2019 12:09 PM
03-23-2006 02:28 AM
Hi Friend,
Yes it supports. Open the link and search for multilink.
http://www.cisco.com/en/US/products/hw/routers/ps368/prod_bulletin09186a0080150a1d.html
HTH, if yes please rate the post.
Ankur
Ankur
03-23-2006 04:11 AM
7609 router has PA-MC-8TE1+ card for E1. Now does this card supports multilink?
03-23-2006 04:34 AM
hi
you can configure MLPP using PA-MC-8TE1+ .
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091c34.html
But at the sametime Multi-chassis Multilink PPP is not supported in both FlexWan and Enhanced FlexWan Modules which you use to install PA-MC-8TE1+ ..
regds
