7600-SIP-200 module in VSS mode
Hello Dears,
Does anyone have an idea, if the  7600-SIP-200 supported in VSS mode or not ?
I have configured to Cisco Catalyst 6513 as VSS, both of them have the  7600-SIP-200 module, before converting them to VSS I was able to work with the  7600-SIP-200 module, but after I did convert them to VSS, both modules didn't work.
here is the show module output, after VSS conversion:
VSS1#show module
Mod Ports Card Type                              Model              Serial No.
  1    0  4-subslot SPA Interface Processor-200  7600-SIP-200       JAE14500GMT
  7    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL15024PV9
10    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL15024Q5R
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  e05f.b95d.e900 to e05f.b95d.e93f   2.303 Unknown      Unknown      PwrDown
  7  c47d.4ffe.8920 to c47d.4ffe.8927   4.0   8.5(4)       12.2(33)SXH8 Ok
10  1cdf.0f1a.e5b0 to 1cdf.0f1a.e5b3   3.2   12.2(14r)S5  12.2(33)SXH8 Ok
Ibra,
Eugene Lau
Hi Ibrahim,
7600-SIP-200 is not supported in VSS mode.
Check out the reference here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/hardware.html#wp2565000
HTH confirm the situation
Eugene.
